change drive
  • jimbojimjay
    • Oct 2008
    • 149
    change drive
    i have a samsung in my 360 at the moment it as been flashed with new f/w it works but i would like to know can i put a lite on in it by reading the samsung and then put the liteon in and then flash it with what i have just took off the samsung i hope i have explained it right thanks
  • on_the_jazz
    • 557
    Yes you can but why do you want to if there is nothing wrong with your Samsung?
    Are you using the new dash? If you don't use Live it will be fine. If you do use Live you might need to somehow spoof the Liteon to be a Samsung. I'm not sure if they check what drive you've got but if they do then it might look weird if you've been playing with a Samsung and then all of a sudden your info changes to Liteon.
    • cunny
      • 4915
      I guess it could be done just check in firmware toobox but i aint heard of anyone doing this, if there is nothing wrong with the sammy then why spoof 1?
      • cunny
        • 4915
        I have just spoofed a hit 46 to a sammy 28, the sammy is a drive you can recover from a bad flash.
        Why would you want to spoof from a sammy to a liteon?
