help flashing xbox 360 slim 4gb
  • pspmixer
    • Jun 2009
    • 750
    ive just bought a xbox 360 slim 4gb model (which is used) and would like to flash it to play backups
    i would like to know the best and easiest way (as i tried doing an xbox elite many years ago and it got read rings when i tryed doing it)
    i only have a laptop to download files etc so if i need extra equipment which ones would i need
    dont know xbox firmware as havnt recieved it yet
    i have been off the xbox scene for a while so lost connect with all updates
    if any one can assist me i would be greatful
    thanks in advance
    MFR date is 2010-09-08 and i have a lite on drive
    it has dashboard: 2.0.12625.0
  • cunny
    • 4915
    Have a read in the stickies. Thats what they are there for
    Sent from my GT-I9300 using Tapatalk 2
    • pspmixer
      • Jun 2009
      • 750
      alot of those tuts use a pc i dont have a pc only a laptop plus can i open it with same tools as xbox elites etc
      • cunny
        • 4915
        Thats just interface fhe actual hack method would be same as to drive. I flash all my drives from my laptop using x360v2. Youcould get a replacement pcb
        • pspmixer
          • Jun 2009
          • 750
          didnt understand that
          explain it in simple terms and wont do i need to flash like what equipment cant plug sata drive into a sata card on a laptop as they dont have slot inside for one
          only thing i have built into my laptop which might help is a esata port
          • cunny
            • 4915
            You will need a x360 v2
            Method used will depend on drive. There is info here in the stickies
            • pspmixer
              • Jun 2009
              • 750
              pcb chip starts with a 03
              where is the cheapest and quickest to get one of them
              • cunny
                • 4915
                You can get replacement chips but require good soldering station an skills. If i remember right u need the sputnik hack for that pcb or replacement pcb
                • shankill2012
                  • Feb 2010
                  • 285
                  Have a look for the "Sputnik switch" and how to install it and you will know what you have to do , 3 solder points and 1 trace cut on the pcb and you will still need the 360 USB pro or similar flashing equipment, I've no soldering skills at all and I've done 2 of these slims successfully .
