Switch to 10 ohms to start with (most work with this) and switch to unlock. Run intro in latest JF - power cycle - then will ask you to unlock the SPI. Click yes and you are done
Grabbed from uber's tutorial
ive already switched the switch on the probe as ive managed to flash a pcb board like this before
ive tried booting in safe mode an running jf that way but still didnt work. tried russian hack too that didnt work either
downloaded a fresh jf too no luck either
im now thinking can i use a old pcb board which i did successfull probe and flash before and use with this console
if so how or would i need that pcb every time i reflash the other xbox
