Least stress with flashing!
  • adhdownload
    • Mar 2009
    The choices are ripe!
    But what is the easiest way to flash a Benq drive?
  • ricky_uk1
    • Mar 2009
    • 116
    probebly either jungleflasher or use the 360mod disc
    v1.52 thats doing the rounds .just pop it in ur ps dvdrom boot from cd and follow the onscreen instructions...
    360 Modification Disc v1.52 by FrostyTheSnowman
    Features:
    - Complete Modding Solution for Samsung/BenQ/Lite-On
    - iXtreme v1.51 (12x) Firmware
    - Supports Samsung TS-H943
    - Supports BenQ VAD6038
    - Supports Lite-On DG-16D2S
    - Supports Previously Modded Drives
    - Supports Previously Spoofed Drives
    - 100% DOS Based Dumping & Flashing
    - Supports FAT32 & NTFS Filesystems (WinXP/Vista 32-Bit & 64-Bit)
    - Fully Automatic Dumping & Flashing
    - Step-by-Step Instructions
    - Backup of all drive-related files to HDD
    Changes in v1.52:
    - Fixed lockup/freezing issues with NTFS drives
    - Improved BenQ/Samsung dumping/flashing stability
    - Replaced MS-DOS with FreeDOS (more stable)
    Changes in v1.51:
    - Updated all firmware to iXtreme v1.51
    - 100% Support for all PC SATA & IDE DVD-ROM drives
    Changes in v1.5 Revision 2:
    - Improved dumping/flashing speeds for BenQ/Samsung drives
    - Added 'user firmware dump verification' prompt to prevent possible BenQ bricking
    - Revised menus and more detailed drive flashing/dumping instructions
    Changes in v1.5 (Public Release):
    - Initial release
    NOTE: This disc requires a VIA VT6421 PCI SATA (or compatible) card
    installed, and an NTFS or FAT32 formatted HDD/partition as the
    'C:' drive for this disc to work properly.
    NOTE 2: This disc *might* work with other types of SATA chipsets/cards,
    but it is recommended that you use a VIA VT6421 SATA card.
    NOTE 3: USB serial adapters are NOT compatible with this disc!
    Usage:
    - Make sure you have a VT6421 (or compatible) PCI SATA card installed in your PC
    - Burn this ISO, and boot this disc in your PC
    - Follow the prompts to mod any Samsung, BenQ, or Lite-On XBOX 360 DVD-ROM drive
    - All firmware dumps, modified firmware, and other files related to the drive being
    modified will be placed in the following directories on your 'C' drive:
    Samsung TS-H943 - C:\SAMFILES
    BenQ VAD6038 - C:\BENFILES
    Lite-On DG-16D2S - C:\LONFILES
    easy peasy
    • C64
      • 2394
      Jungle Flasher for everything these days mate.
