cannot see xbox on pc
  • the goat
    • Mar 2010
    • 122
    hi
    just got an rgh xbox for my lad
    been trying for days to get lappy to see xbox
    been into the router and it sees both xbox and lappy
    put in the ip address of xbox into ftp flash, but does not pick up xbox
    xbox does link to lappy via media player
    but i want to put games on to hdd from the lappy
    disabled the firewalls still no joy
    any help please
  • cunny
    • 4915
    Are you running FSD? (freestyle dash?)
    • the goat
      • Mar 2010
      • 122
      when i tried to run FSD it said something like "dashlauncher v2.27 cannot work with kernel ver 15574"
      but the dash has changed from the one it came with, so not sure if this one is fsd,but there is a fsd credit tab on the dash
      as you can see i'm new to all of this,
      like i've said in other posts i'm an oldie, and it really does hurt my head trying to get this techo stuff working
      vista on lappy
      • cunny
        • 4915
        Ok.. Does the console still boot xell reloaded when powering on from the eject button?
        Try loading FSD from from memory stick. You will need to burn a copy of XeX menu and browse to usb and boot it from there.
        FSD installer : Freestyle Dashboard 2.2 Auto Installer (ISO, Live and XEX options)
        XeX Menu can be found on xbins
        So get Xex Menu, burn to disc. Instal FSD to usb device ie usb stick and load via Xex Menu
        • the goat
          • Mar 2010
          • 122
          i'll try that a bit later
          • cunny
            • 4915
            Xex menu
            XEXMenu 1.1 Download [XEX Menu ISO, LIVE and XEX] - File manager for Xbox 360
            • the goat
              • Mar 2010
              • 122
              got xexmenu on and running,
              but still can't get pc to see xbox or xbox to see pc
              if i use windows media centre the pc picks up the xbox
              so i know that something works
              but i juct cannot get ftp flash to find xbox
              or the xbox to find pc in the systems setting section
              • cunny
                • 4915
                Now you have XeX menu running you need to get FSD running. You can instal this onto a flash drive (usb stick) or on the hdd itself.
                Once this is running post back and i will tell you how to FTP accross.
                Or alternatly you could just instal FSD straight onto the xbox hdd. Coice is yours.
                • the goat
                  • Mar 2010
                  • 122
                  thanks cunny
                  I tried smartFTP and it managed to see Xbox from PC
                  so it must have been Flash FTP was not working or wrongly configured
                  • the goat
                    • Mar 2010
                    • 122
                    guys just to add
                    i found that i needed to be on my rgh avator before my pc could see the xbox
