some xgd3 games burn ok but dont work
  • dragazar
    • Apr 2011
    • 59
    hi i have tried a lot of things so far i have tried using verbs and Aone. I think they seem to burn ok i am going to post my kprobe results here shortly any help appreciated. All get from my xbox when i try play for example BL2 is no picture and says play game then disc unreadable
    Kprobe resuslts
    All setings are ON except overspeed, im burning 4x ihas24b
    OPC ON
    PS. I think i burnt this one at 8x
    Click thanks if i helped by asking a good question or helped
  • cunny
    • 4915
    And abgx log please
    Sent from my GT-I9300 using Tapatalk 2
    • dragazar
      • Apr 2011
      • 59
      hope this pic is ok, are there any more individual patches around ?
      Does the kprobe test look ok i dont know see . Thanks for fast reply by way
      [IMG]Digital Kaos - The Cable and Satellite Experts!:image/gif,GIF89a%12%00%12%00%B3%00%00%FF%FF%FF%F7%F7%EF% CC%CC%CC%BD%BE%BD%99%99%99ZYZRUR%00%00%00%FE%01%02 %00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%0 0%00%00%00%00!%F9%04%04%14%00%FF%00%2C%00%00%00%00 %12%00%12%00%00%04X0%C8I%2B%1D8%EB%3D%E4%00%60(%8A %85%17%0AG*%8C%40%19%7C%00J%08%C4%B1%92%26z%C76%FE %02%07%C2%89v%F0%7Dz%C3b%C8u%14%82V5%23o%A7%13%19L %BCY-%25%7D%A6l%DF%D0%F5%C7%02%85%5B%D82%90%CBT%87%D8i7 %88Y%A8%DB%EFx%8B%DE%12%01%00%3B[/IMG][IMG]http://www.digital-kaos.co.uk/forums/data:image/gif,GIF89a%12%00%12%00%B3%00%00%FF%FF%FF%F7%F7%EF% CC%CC%CC%BD%BE%BD%99%99%99ZYZRUR%00%00%00%FE%01%02 %00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%0 0%00%00%00%00!%F9%04%04%14%00%FF%00%2C%00%00%00%00 %12%00%12%00%00%04X0%C8I%2B%1D8%EB%3D%E4%00%60(%8A %85%17%0AG*%8C%40%19%7C%00J%08%C4%B1%92%26z%C76%FE %02%07%C2%89v%F0%7Dz%C3b%C8u%14%82V5%23o%A7%13%19L %BCY-%25%7D%A6l%DF%D0%F5%C7%02%85%5B%D82%90%CBT%87%D8i7 %88Y%A8%DB%EFx%8B%DE%12%01%00%3B[/IMG]
      • cunny
        • 4915
        U need to slow it down. Pif max is too high
        • dragazar
          • Apr 2011
          • 59
          thanks il try now and post resuts
          • stewy101
            • Mar 2009
            • 18
            all i would say is use Verbatims with imgburn, you can get the settings online also I use ihas24 with burner max firmware..all mine burn and work 1st time...aone are ok xgd2 games but not the new ones...
            • pfj_official
              • 65
              Maybe be a drive/laser issue? I've burned games (XDG3) which work on my console flawlessy but don't work on son's console. As also mentioned use Verbatims, burn at 2.4 x and use iHas burner with Imgburn.
              • snedz
                • Sep 2012
                • 9
                check my log aone gold works perect evertime
                check opc on or off
                hyper on
                online on
                overspeed off
                smartburn on
                4x speed burn and verify imgburn
                who needs verbs
                I 13:35:32 ImgBurn Version 2.5.7.0 started!
                I 13:35:32 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
                I 13:35:32 Total Physical Memory: 2,095,920 KB - Available: 1,659,804 KB
                I 13:35:32 Initialising SPTI...
                I 13:35:32 Searching for SCSI / ATAPI devices...
                I 13:35:33 -> Drive 1 - Info: PIONEER DVD-RW DVR-116D 1.09 (E (ATA)
                I 13:35:33 -> Drive 2 - Info: ATAPI iHAS524 B AL2A (F (USB)
                I 13:35:33 Found 1 DVD?RW and 1 DVD?RW/RAM!
                I 13:38:39 Operation Started!
                I 13:38:39 Source File: D:\Downloads\Medal of Honor Warfighter iMARS Disc 2 Single Player\imars-mohw2-360.dvd
                I 13:38:39 Source File Sectors: 4,267,015 (MODE1/2048)
                I 13:38:39 Source File Size: 8,738,846,720 bytes
                I 13:38:39 Source File Volume Identifier: DVD_ROM
                I 13:38:39 Source File Volume Set Identifier: dd94c000MS UDFBridge
                I 13:38:39 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
                I 13:38:39 Source File Implementation Identifier: Microsoft CDIMAGE UDF
                I 13:38:39 Source File File System(s): ISO9660, UDF (1.50)
                I 13:38:39 Destination Device: [0:0:0] ATAPI iHAS524 B AL2A (F (USB)
                I 13:38:39 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67)
                I 13:38:39 Destination Media Supported Write Speeds: 4x, 6x, 8x
                I 13:38:39 Destination Media Sectors: 4,267,040
                I 13:38:39 Write Mode: DVD
                I 13:38:39 Write Type: DAO
                I 13:38:39 Write Speed: 4x
                I 13:38:39 DVD+R DL Reserve Track: No
                I 13:38:39 Link Size: Auto
                I 13:38:39 Lock Volume: Yes
                I 13:38:39 Test Mode: No
                I 13:38:39 OPC: No
                I 13:38:39 BURN-Proof: Enabled
                I 13:38:39 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
                I 13:38:39 Book Type Setting: DVD-ROM
                I 13:38:39 Advanced Settings - Force HT: Yes, Online HT: Yes, OverSpeed: No, SmartBurn: Yes
                I 13:38:39 Optimal L0 Data Zone Capacity: 2,133,520
                I 13:38:39 Optimal L0 Data Zone Method: Copied From Original Disc
                I 13:38:39 Set L0 Data Zone Capacity Succeeded!
                I 13:38:40 Filling Buffer... (80 MB)
                I 13:38:43 Writing LeadIn...
                I 13:38:48 Writing Session 1 of 1... (1 Track, LBA: 0 - 4267014)
                I 13:38:48 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 4267014)
                I 13:38:48 Writing Layer 0... (LBA: 0 - 2133519)
                I 13:52:03 Writing Layer 1... (LBA: 2133520 - 4267014)
                I 14:05:25 Synchronising Cache...
                I 14:05:38 Closing Track...
                I 14:05:39 Finalising Disc...
                I 14:06:13 Exporting Graph Data...
                I 14:06:13 Graph Data File: C:\Documents and Settings\Snedz\Application Data\ImgBurn\Graph Data Files\ATAPI_iHAS524_B_AL2A_22-OCTOBER-2012_13-38_RICOHJPN-D01-67_4x.ibg
                I 14:06:13 Export Successfully Completed!
                I 14:06:13 Operation Successfully Completed! - Duration: 00:27:34
                I 14:06:13 Average Write Rate: 5,347 KB/s (3.9x) - Maximum Write Rate: 5,618 KB/s (4.1x)
                I 14:06:13 Cycling Tray before Verify...
                W 14:06:21 Waiting for device to become ready...
                I 14:06:35 Device Ready!
                I 14:06:36 Operation Started!
                I 14:06:36 Source Device: [0:0:0] ATAPI iHAS524 B AL2A (F (USB)
                I 14:06:36 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67)
                I 14:06:36 Source Media Supported Write Speeds: 4x, 6x, 8x
                I 14:06:36 Image File: D:\Downloads\Medal of Honor Warfighter iMARS Disc 2 Single Player\imars-mohw2-360.dvd
                I 14:06:36 Image File Sectors: 4,267,015 (MODE1/2048)
                I 14:06:36 Image File Size: 8,738,846,720 bytes
                I 14:06:36 Image File Volume Identifier: DVD_ROM
                I 14:06:36 Image File Volume Set Identifier: dd94c000MS UDFBridge
                I 14:06:36 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
                I 14:06:36 Image File Implementation Identifier: Microsoft CDIMAGE UDF
                I 14:06:36 Image File File System(s): ISO9660, UDF (1.50)
                I 14:06:36 Read Speed (Data/Audio): MAX / MAX
                I 14:06:37 Verifying Session 1 of 1... (1 Track, LBA: 0 - 4267014)
                I 14:06:37 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 4267014)
                I 14:06:37 Verifying Layer 0... (LBA: 0 - 2133519)
                I 14:12:48 Verifying Layer 1... (LBA: 2133520 - 4267014)
                I 14:18:59 Exporting Graph Data...
                I 14:18:59 Graph Data File: C:\Documents and Settings\Snedz\Application Data\ImgBurn\Graph Data Files\ATAPI_iHAS524_B_AL2A_22-OCTOBER-2012_13-38_RICOHJPN-D01-67_4x.ibg
                I 14:18:59 Export Successfully Completed!
                I 14:18:59 Operation Successfully Completed! - Duration: 00:12:21
                I 14:18:59 Average Verify Rate: 11,532 KB/s (8.3x) - Maximum Verify Rate: 16,856 KB/s (12.2x)
