hi can any1 explain ive dloaded fifa 13 and tried to burn it with img burn and it says not enough room on disk on my 8.5gb why do they put files on the sites larger than u can burn or is there someyhing im not doin right ive even truncated it and overburned it as well any answers on this 1 plz jon.......
fifa 13
look up burner max firmware and xdg3hi can any1 explain ive dloaded fifa 13 and tried to burn it with img burn and it says not enough room on disk on my 8.5gb why do they put files on the sites larger than u can burn or is there someyhing im not doin right ive even truncated it and overburned it as well any answers on this 1 plz jon.......sigpic
ihas burner required also these settings I 13:38:39 Advanced Settings - Force HT: Yes, Online HT: Yes, OverSpeed: No, SmartBurn: Yes these settngs aone gold discs
I 13:35:32 ImgBurn Version 2.5.7.0 started!
I 13:35:32 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 13:35:32 Total Physical Memory: 2,095,920 KB - Available: 1,659,804 KB
I 13:35:32 Initialising SPTI...
I 13:35:32 Searching for SCSI / ATAPI devices...
I 13:35:33 -> Drive 1 - Info: PIONEER DVD-RW DVR-116D 1.09 (E
(ATA)
I 13:35:33 -> Drive 2 - Info: ATAPI iHAS524 B AL2A (F
(USB)
I 13:35:33 Found 1 DVD?RW and 1 DVD?RW/RAM!
I 13:38:39 Operation Started!
I 13:38:39 Source File: D:\Downloads\Medal of Honor Warfighter iMARS Disc 2 Single Player\imars-mohw2-360.dvd
I 13:38:39 Source File Sectors: 4,267,015 (MODE1/2048)
I 13:38:39 Source File Size: 8,738,846,720 bytes
I 13:38:39 Source File Volume Identifier: DVD_ROM
I 13:38:39 Source File Volume Set Identifier: dd94c000MS UDFBridge
I 13:38:39 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
I 13:38:39 Source File Implementation Identifier: Microsoft CDIMAGE UDF
I 13:38:39 Source File File System(s): ISO9660, UDF (1.50)
I 13:38:39 Destination Device: [0:0:0] ATAPI iHAS524 B AL2A (F
(USB)
I 13:38:39 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67)
I 13:38:39 Destination Media Supported Write Speeds: 4x, 6x, 8x
I 13:38:39 Destination Media Sectors: 4,267,040
I 13:38:39 Write Mode: DVD
I 13:38:39 Write Type: DAO
I 13:38:39 Write Speed: 4x
I 13:38:39 DVD+R DL Reserve Track: No
I 13:38:39 Link Size: Auto
I 13:38:39 Lock Volume: Yes
I 13:38:39 Test Mode: No
I 13:38:39 OPC: No
I 13:38:39 BURN-Proof: Enabled
I 13:38:39 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 13:38:39 Book Type Setting: DVD-ROM
I 13:38:39 Optimal L0 Data Zone Capacity: 2,133,520
I 13:38:39 Optimal L0 Data Zone Method: Copied From Original Disc
I 13:38:39 Set L0 Data Zone Capacity Succeeded!
I 13:38:40 Filling Buffer... (80 MB)
I 13:38:43 Writing LeadIn...
I 13:38:48 Writing Session 1 of 1... (1 Track, LBA: 0 - 4267014)
I 13:38:48 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 4267014)
I 13:38:48 Writing Layer 0... (LBA: 0 - 2133519)
I 13:52:03 Writing Layer 1... (LBA: 2133520 - 4267014)
I 14:05:25 Synchronising Cache...
I 14:05:38 Closing Track...
I 14:05:39 Finalising Disc...
I 14:06:13 Exporting Graph Data...
I 14:06:13 Graph Data File: C:\Documents and Settings\Snedz\Application Data\ImgBurn\Graph Data Files\ATAPI_iHAS524_B_AL2A_22-OCTOBER-2012_13-38_RICOHJPN-D01-67_4x.ibg
I 14:06:13 Export Successfully Completed!
I 14:06:13 Operation Successfully Completed! - Duration: 00:27:34
I 14:06:13 Average Write Rate: 5,347 KB/s (3.9x) - Maximum Write Rate: 5,618 KB/s (4.1x)
I 14:06:13 Cycling Tray before Verify...
W 14:06:21 Waiting for device to become ready...
I 14:06:35 Device Ready!
I 14:06:36 Operation Started!
I 14:06:36 Source Device: [0:0:0] ATAPI iHAS524 B AL2A (F
(USB)
I 14:06:36 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67)
I 14:06:36 Source Media Supported Write Speeds: 4x, 6x, 8x
I 14:06:36 Image File: D:\Downloads\Medal of Honor Warfighter iMARS Disc 2 Single Player\imars-mohw2-360.dvd
I 14:06:36 Image File Sectors: 4,267,015 (MODE1/2048)
I 14:06:36 Image File Size: 8,738,846,720 bytes
I 14:06:36 Image File Volume Identifier: DVD_ROM
I 14:06:36 Image File Volume Set Identifier: dd94c000MS UDFBridge
I 14:06:36 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
I 14:06:36 Image File Implementation Identifier: Microsoft CDIMAGE UDF
I 14:06:36 Image File File System(s): ISO9660, UDF (1.50)
I 14:06:36 Read Speed (Data/Audio): MAX / MAX
I 14:06:37 Verifying Session 1 of 1... (1 Track, LBA: 0 - 4267014)
I 14:06:37 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 4267014)
I 14:06:37 Verifying Layer 0... (LBA: 0 - 2133519)
I 14:12:48 Verifying Layer 1... (LBA: 2133520 - 4267014)
I 14:18:59 Exporting Graph Data...
I 14:18:59 Graph Data File: C:\Documents and Settings\Snedz\Application Data\ImgBurn\Graph Data Files\ATAPI_iHAS524_B_AL2A_22-OCTOBER-2012_13-38_RICOHJPN-D01-67_4x.ibg
I 14:18:59 Export Successfully Completed!
I 14:18:59 Operation Successfully Completed! - Duration: 00:12:21
I 14:18:59 Average Verify Rate: 11,532 KB/s (8.3x) - Maximum Verify Rate: 16,856 KB/s (12.2x)Last edited by snedz; 22 October, 2012, 16:30.
