HITACHI 79 cant get key :(
  • c411umh
    The link helped me out, I had the exact same problem
    • lingwall
      Thanks for the link
      • richy_2k
        • Jul 2010
        • 5
        #18
        Sorry, I'm posting for the unlock cd attachment. Every other I've tried hasn't worked.
        • richy_2k
          • Jul 2010
          • 5
          #19
          How many posts???
          • richy_2k
            • Jul 2010
            • 5
            #20
            I'm desperate, the unlock CDs just don't play at all!!!!!
            • richy_2k
              • Jul 2010
              • 5
              #21
              HOw many posts are needed?
              • richy_2k
                • Jul 2010
                • 5
                #22
                Maybe 5 posts?
                • deffc0n
                  • Aug 2009
                  • 894
                  #23
                  Just succesfully flashed a 78 and a 79 in Vista32 with Via 6421
                  Followed the JF manual closely but not completely.
                  Fresh vista 32 install (as I use 64 bit)
                  .NET Framework 3.5 SP1 and updates all installed
                  Installed portIO 32 manually
                  Installed viamraid.sys manually after port I/O installed (could not dump firmware useing port I/O commands in JF)
                  Opened JF set Mode B, did the drive door open, unplug, wait, plug back in and close drive door on 78 Mode B set
                  For 79 had to use the unlock CD
                  Waited for windows to pick up drive, then refreshed list and drive was there
                  Then switched from Port I/O mode to Win Api mode and dumped the drive, once dumped saved to the firmware folder as specified in JF README
                  Got all my drive info so I knew which firmware to add to that folder, both the original version, and the iXtreme version, as my drive had 1.4 on it
                  Then restored the firmware as asked to set up the flash, and saved the original to a different location.
                  Then clicked flash iXtreme, waited for it to complete, and then shut down PC, unplugged drive, and all was good when re-installed to the XBOX
                  Good luck all, hope this helps some of you.
                  • branschwe
                    • Nov 2010
                    thanks ive been searching for this for a while
                    • slt780
                      • Feb 2011
                      I'm having the same problem...Xbox won't read the 79unlock CD. Any suggestions?
                      • janobi
                        • 1624
                        #26
                        You burnt it right? When you say it wont read it, what actually happens?
