Ok Good Settings That Burn and Verify and Install 100% For Aone Gold Discs
If They Dont Play Check Ur Laser (pot Tweak , or like mine the white grip on on rail liteon drive replaced screw)
So First Make Sure
Opc- On or Off (dosent make a dif to me)
then advanced setting imgburn
Hyper on
Overspeed 0ff
Online on
smartburn on
set 4x speed and verify o imgburn works evry time check my log for medal
I 13:35:32 ImgBurn Version 2.5.7.0 started!
I 13:35:32 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 13:35:32 Total Physical Memory: 2,095,920 KB - Available: 1,659,804 KB
I 13:35:32 Initialising SPTI...
I 13:35:32 Searching for SCSI / ATAPI devices...
I 13:35:33 -> Drive 1 - Info: PIONEER DVD-RW DVR-116D 1.09 (E
(ATA)
I 13:35:33 -> Drive 2 - Info: ATAPI iHAS524 B AL2A (F
(USB)
I 13:35:33 Found 1 DVD?RW and 1 DVD?RW/RAM!
I 13:38:39 Operation Started!
I 13:38:39 Source File: D:\Downloads\Medal of Honor Warfighter iMARS Disc 2 Single Player\imars-mohw2-360.dvd
I 13:38:39 Source File Sectors: 4,267,015 (MODE1/2048)
I 13:38:39 Source File Size: 8,738,846,720 bytes
I 13:38:39 Source File Volume Identifier: DVD_ROM
I 13:38:39 Source File Volume Set Identifier: dd94c000MS UDFBridge
I 13:38:39 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
I 13:38:39 Source File Implementation Identifier: Microsoft CDIMAGE UDF
I 13:38:39 Source File File System(s): ISO9660, UDF (1.50)
I 13:38:39 Destination Device: [0:0:0] ATAPI iHAS524 B AL2A (F
(USB)
I 13:38:39 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67)
I 13:38:39 Destination Media Supported Write Speeds: 4x, 6x, 8x
I 13:38:39 Destination Media Sectors: 4,267,040
I 13:38:39 Write Mode: DVD
I 13:38:39 Write Type: DAO
I 13:38:39 Write Speed: 4x
I 13:38:39 DVD+R DL Reserve Track: No
I 13:38:39 Link Size: Auto
I 13:38:39 Lock Volume: Yes
I 13:38:39 Test Mode: No
I 13:38:39 OPC: No
I 13:38:39 BURN-Proof: Enabled
I 13:38:39 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 13:38:39 Book Type Setting: DVD-ROM
I 13:38:39 Advanced Settings - Force HT: Yes, Online HT: Yes, OverSpeed: No, SmartBurn: Yes
I 13:38:39 Optimal L0 Data Zone Capacity: 2,133,520
I 13:38:39 Optimal L0 Data Zone Method: Copied From Original Disc
I 13:38:39 Set L0 Data Zone Capacity Succeeded!
I 13:38:40 Filling Buffer... (80 MB)
I 13:38:43 Writing LeadIn...
I 13:38:48 Writing Session 1 of 1... (1 Track, LBA: 0 - 4267014)
I 13:38:48 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 4267014)
I 13:38:48 Writing Layer 0... (LBA: 0 - 2133519)
I 13:52:03 Writing Layer 1... (LBA: 2133520 - 4267014)
I 14:05:25 Synchronising Cache...
I 14:05:38 Closing Track...
I 14:05:39 Finalising Disc...
I 14:06:13 Exporting Graph Data...
I 14:06:13 Graph Data File: C:\Documents and Settings\Snedz\Application Data\ImgBurn\Graph Data Files\ATAPI_iHAS524_B_AL2A_22-OCTOBER-2012_13-38_RICOHJPN-D01-67_4x.ibg
I 14:06:13 Export Successfully Completed!
I 14:06:13 Operation Successfully Completed! - Duration: 00:27:34
I 14:06:13 Average Write Rate: 5,347 KB/s (3.9x) - Maximum Write Rate: 5,618 KB/s (4.1x)
I 14:06:13 Cycling Tray before Verify...
W 14:06:21 Waiting for device to become ready...
I 14:06:35 Device Ready!
I 14:06:36 Operation Started!
I 14:06:36 Source Device: [0:0:0] ATAPI iHAS524 B AL2A (F
(USB)
I 14:06:36 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67)
I 14:06:36 Source Media Supported Write Speeds: 4x, 6x, 8x
I 14:06:36 Image File: D:\Downloads\Medal of Honor Warfighter iMARS Disc 2 Single Player\imars-mohw2-360.dvd
I 14:06:36 Image File Sectors: 4,267,015 (MODE1/2048)
I 14:06:36 Image File Size: 8,738,846,720 bytes
I 14:06:36 Image File Volume Identifier: DVD_ROM
I 14:06:36 Image File Volume Set Identifier: dd94c000MS UDFBridge
I 14:06:36 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
I 14:06:36 Image File Implementation Identifier: Microsoft CDIMAGE UDF
I 14:06:36 Image File File System(s): ISO9660, UDF (1.50)
I 14:06:36 Read Speed (Data/Audio): MAX / MAX
I 14:06:37 Verifying Session 1 of 1... (1 Track, LBA: 0 - 4267014)
I 14:06:37 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 4267014)
I 14:06:37 Verifying Layer 0... (LBA: 0 - 2133519)
I 14:12:48 Verifying Layer 1... (LBA: 2133520 - 4267014)
I 14:18:59 Exporting Graph Data...
I 14:18:59 Graph Data File: C:\Documents and Settings\Snedz\Application Data\ImgBurn\Graph Data Files\ATAPI_iHAS524_B_AL2A_22-OCTOBER-2012_13-38_RICOHJPN-D01-67_4x.ibg
I 14:18:59 Export Successfully Completed!
I 14:18:59 Operation Successfully Completed! - Duration: 00:12:21
I 14:18:59 Average Verify Rate: 11,532 KB/s (8.3x) - Maximum Verify Rate: 16,856 KB/s (12.2x)
So First Make Sure
Hyper on
Overspeed 0ff
Online on
smartburn on
(ATA)I 13:35:33 -> Drive 2 - Info: ATAPI iHAS524 B AL2A (F
(USB)I 13:35:33 Found 1 DVD?RW and 1 DVD?RW/RAM!
(USB)I 13:38:39 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67)
I 13:38:39 OPC: No
(USB)I 14:06:36 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67)
