unchip xbox 360
  • Cod3waX
    • 1011
    unchip xbox 360
    is it possible to unchip an xbox 360 to then play with it on live?
    also will the firmware need to be flashed?
    thanks for the help
  • cunny
    • 4915
    Your gonna have to be more specific. Is it drive flashed? Rgh or jtag?
    Also would depend if it's been banned from live or flagged.
    Sent from my GT-I9300 using Tapatalk 2
    • ray156
      • 669
      as mr cunny says.cause all those games played till now,will have registred on box.and it could be flagged.etc.best bet would be keep box as is.just for playing on.get another box never been flashed etc.use that for online.
      • Cod3waX
        • 1011
        rite i have it now
        i asked how its was chipped or flashed n he didnt know as he bought it like it
        so if i loaded it up without internet connection could i find out how it is working from that method and then un-chip it?
        • cunny
          • 4915
          Does it play back ups from disc or hdd?
          More than likely its a drive flash and would need returning to stock firmware.
          If that is the case. Depends on drive and dash version as to which stock firmware.
          • Cod3waX
            • 1011
            the games load from discs and the dashboard is very very old
            • Cod3waX
              • 1011
              • cunny
                • 4915
                Then I'd look at returning drive to stock firmware. Again depending on drive as to firmware used
                • Cod3waX
                  • 1011
                  so it hasnt been chipped just flashed??
                  how do u flash the drive is it from disc or direct connection to pc?
                  • cunny
                    • 4915
                    By the sound and look of things its just a drive flash
                    • Cod3waX
                      • 1011
                      ok i have a phillips & lite-on drive Modle no. DG-16D2S
                      will the stock lite-on rar work?
                      do i have to conect the drive to the pc to use this or can i burn it to disc then use it in the xbox ?
                      do i need the ck3 to write back the original firmware?
                      • cunny
                        • 4915
                        You will need more than a .ck3 a probe v3 to retrieve drive key will be needed also.
                        Yes you will need to connect drive to a pc thro compatible chipset also.
                        • Cod3waX
                          • 1011
                          i can connect the sata to the pc and power the disc drive with the xbox
                          can i do flash back without ck3?
                          • cunny
                            • 4915
                            If you have the key yes, however can be tricky. Its also not recomended doing it that way.
                            If you dont have the key then no.
                            My advice? Either get the equipment needed or take it someone to do
                            • Cod3waX
                              • 1011
                              it is the worst that will happen if i connected it the internet and then let it update?
