using XBC question?
  • m9g
    • 704
    using XBC question?
    Hi
    Never looked at making backups of my originals but thought bit bored i'd have a look.
    I've been reading about using a kreon flashed drive but now not a good idea with xdg3 out so I was wondering if its possible to use a hitachi drive? if so would it need to be flashed or not and how do i go about using it?
    If not, then what can i use?
    Cheers
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
  • cunny
    • 4915
    Originally posted by m9g
    Hi
    Cheers
    BenQ/Liteon flashed with 0800v3 fw or any xbox drive with a x360usb v2
    • m9g
      • 704
      Cheers Cunny
      OOOoooo just so happens I found a BenQ drive under the sofa - how it got there i dont know but woohoo!!!!
      Right, just to find a tut now on how to flash it with 0800 v3
      • cunny
        • 4915
        Same as any benq just don't need a key
        Sent from my GT-I9300 using Tapatalk 2
        • m9g
          • 704
          Blimey looking at the time of your last post you havent had much sleep or have you just not gone to bed
          So just flash same way as if flashing with LT but use the 0800 fw?
          • cunny
            • 4915
            Yes just you don't require a drive key due to the drive not going in an xbox.
            I'm up early every day
            • m9g
              • 704
              ok so i have flashed with the 0800 v3 - i take it it wont hurt to have the original key spoofed across to the 0800 v3 firmware?
              So now what do i do with it to be able to use it with XBC?
              Cheers
              • cunny
                • 4915
                Ok guys you've heard of 0800 firmware for backing up XBOX 360 games, well this is how you do it. Also this method will give you SSv2 that is prefered by all newer firmware coming out. Through this, I will show you how to setup to RIP a game to your PC, check and Patch it, then Burn it to Disc using a XBOX 360 DVD Drive &
                • m9g
                  • 704
                  Lovely :-) all sorted, was nearly right only bit i missed was opening drive and closing half way before pc recognising it.
                  Cheers Cunny
