I want to add a usb HDD to my xbox 360, I have a 2.5 sata HDD but need to buy a caddy, I have been told that not all caddies will work, so was wanting to know if anyone has succeeded in doing this and what one did they use?
if its not glitched you can only go up 16gb in 1 port
'Allows up to two USB flash drives or external hard drives to be used for storing profiles, game saves, demos and more up to 16 GB each, 32GB combined'
If its glitched/jtag i dont think it matters, will just need formatting in fat32
The xbox has been jtag, I just wanted to add a hdd rather than change the one that was already in the xbox thanks
Mine is a 3.5" usb 3 enclosure, have just looked and my local shop stopped supplying them, however they do a 2.5" however its usb powered and i am unsure if this will work.
If the 1 you want to put in a USB enclosre put it in the 1 for the xbox as its jtagged it can be any 2.5" HDD
