I tried flashing a Hitachi 59 last night. JF said the flash was successful, but the drive will not eject. I open the drive manually and power the drive up and the tray closes, but when I press eject on JF or my CK3i it will not open. I also tried the drive in the Xbox and the drive will still not eject. There is no movement from the drive when I press eject, any ideas
Hitachi 59 disc tray will not open
I had one that did that manually open the drive tray and look for the rubber band on the big and little runner wheels. Take the band off now this is gonna sound mad but boil the kettle put the rubber band into a mug wait for the kettle to boil then pour the boiling water into the mug leave it for ten seconds then put cold water into the mug this will cause the band to shrink
Dry the band and put it back where it should be and see if that worksComment
Its worth a try like but if it was working fine before flashing he may have inadvertently shorted something.
As long as he's got his drive key he will be ok the worst scenario is a new drive.Comment
stuck in b mode by the sounds of it reflash drive unplug power for ck3 plug cables back in and turn it on in the xbox also maybe tray sticks had one like that would eject if disk was in drive but if not it would stick had to press drive tray in the way when pushing ejectLast edited by TheMegaSnedz1888; 22 November, 2012, 16:48.Comment
also hitachi are crap at reading backups would get a better drive i use a liteon instead of my hitachi 47 iv no been banned yet 4 years and counting tic tock
I have my drive key so if I do need a new drive that will not be a problem. I thought it might be stuck in mode b but I thought as soon as you turned the power of the drive reset. I will have another go at flashing back to stock and reflashing. It this fails I think I will buy a new drive.Comment
