3 rrod xbox's
  • pspmixer
    • Jun 2009
    • 750
    3 rrod xbox's
    just bought 3 rrod xbox 360
    2 elite console
    1 arcade conosle
    anyone know how to fix this
    as id like to flash them at some point if can be fixed
  • pauleemor
    • 92
    try a new power supply first as causes rrd
    • pspmixer
      • Jun 2009
      • 750
      so swap one inside the console or new lead
      • bowie
        • 475
        look on youtube. loads of vids showing you how. did mine a few years back
        Men of Harlech onto glory
        This shall ever be your story
        Keep these fighting words before ye
        Cambria will not yield
        • pauleemor
          • 92
          power supply that you know works did my daughters this week as had rrod changed power lead and works 100% now
          • pspmixer
            • Jun 2009
            • 750
            p.m one used or comment it on here
            ive only got one lead where can i get one
            • pauleemor
              • 92
              try a friends that you know works and see result before you buy you can pick up from about ?20
              • cunny
                • 4915
                Get secondary code.
                Strip down so motherboard is out.
                Remove xclamps
                Clean up cpu and gpu
                Buy some machine screws
                Replace xclamps with decent thermal paste.
                Put kpads on ram chips
                Reseat board.
                With fans disconnected power up console allowing to over heat
                Once over heated power off at mains
                Leave for 20 mins to cool down.
                Recollect fans and power up
                Sent from my GT-I9300 using Tapatalk 2
                • cunny
                  • 4915
                  You can also buy rrod repair kits from xecuter. Think it's the extreme edition now
                  • pspmixer
                    • Jun 2009
                    • 750
                    are they good and do they work
                    http://www.modtraders.co.uk/xecuter-...t-version.html
                    http://www.modtraders.co.uk/tx-xbox-...e-edition.html
                    http://www.modtraders.co.uk/xecuter-...-10-xboxs.html
                    • cunny
                      • 4915
                      Never used 1 however I'd imagine they work as from xecuter.
                      I've repaired a few with above method
                      • bowie
                        • 475
                        i did exactly what cunny has mentioned. can't remember which vid i followed mate. but there are plenty to follow. tbh though i had the rrod again about 9 months later and had to clean it up again. it looks tricky but it really isn't
                        • bowie
                          • 475
                          you can also buy rrod x clamp repair kits on fleabay
                          • pspmixer
                            • Jun 2009
                            • 750
                            manged to get number of the elite console
                            one was 0110 green light on power brick
                            other was 0001 red light on power brick
                            i couldnt get numbers of white xbox as tray kept coming out it didn have 3 red lights on front
                            but what i weird is when i plugged av leads in turned on the console it works no red rights or nothing (could i flash this one then )
                            for all them i used a new power brick and lead as just bought one off amazon for ?8 and no hard rive on any of them
                            • ezzda1
                              • 172
                              0110 = E20: likely a Ram error, this can be caused by a cold or bridged solder joint on one of the Ram chips. reflow the ram area with a hot air reflow station.
                              0001 = E01: possibly a power supply problem, if it's been tested with known working power supply it's most likely a blown mosfet on the motherboard, time to crack the multimeter out to test the mosfets. and check for any short circuits on the board.
                              like this
                              Forums.Xbox-experts.com - an easy way to fix 0001/0002/0003
                              if it boots up and displays picture and has sound, yes you can flash it.
                              just make sure it plays original games before you mess with it,
                              if it doesn't you may be looking at a bad laser or lost drive key depending on what it can play.
