Lt3.0 fw now can't play lt2.0 games !!
  • scottj130208
    • Apr 2011
    • 323
    Updated to lt3.0 firmware but unable to play lt2.0 games they say unsupported disc do the 2.0 games need to go through agbx again and re burned to play with 3.0 firmware I thought the new 3.0 would let you play 2.0 games thanks
  • roycar69
    • Dec 2012
    I get the same error. I can install the game fine but when I try to run it I get the unsupported disc error. Anyone with an answer?
    • cunny
      • 4915
      There is no such thing as LT2.0 games.
      Maybe a copy of abgx logs and kprobe results would help
      • felix11
        • 151
        When you update to LT3.0 any XDG3 iso's burned for use with LT2.0 need to be re-patched through abgx and re-burned for them to work. When you put one thru abgx you will see that the topology section is missing - that ia what is causing the unsupported disc error.
        Most older games will not need to be re-burned as they are noty AP25 active, but some are so you will need to see which work and which dont. However all xdg3 titles are AP25 active and will threfore need re-burning.
        • parksy87
          • Dec 2012
          as above i had the same issue had problems running my back up of mass effect and and most wanted etc, flashed 3.0 and it solved that problem although had to repatch and burn them
          • geo321
            • Jan 2013
            I suppose patching to lt2.0 topology should get rid of the disc unreadable error on the newer games?
            • tai1976
              • Feb 2013
              Technically there is no LT+ 2.0 topology anymore. ABGX360's current topology only supports LT+ 3.0 or LTU 1.2. There are a couple exceptions including early Samsung and Hitachi drives which do not handle AP2.5 challenges.
              Perhaps you meant LT+ 3.0 in your post?
