need help
  • Time2Play
    • Apr 2009
    • 309
    need help
    hey al i have a benq vad38 i was trying to get drive in to vendor mode with jungle flash i plugged it up hit benq unlock it started sending the magic keys when i hit my sata cable out accidently now the drive has aE65 error i was told it can be recovered the bad flash anyone know how please thaqnks
    SAY THANKS OR JOK WILL TAKE PICTURES OF YOU IN YOUR SLEEP
  • cunny
    • 4915
    did you retrieve the key?
    • Time2Play
      • Apr 2009
      • 309
      no it crashed before i could retrevve key but iv read with the model of drive it is there is a possability of recovering th ebad flash BenQ VAD6038
      • cunny
        • 4915
        I will look into it, do you have the jungleflasher logs?
        If are getting the error thats bad firmware then you could have screwed it because sounds like you have sent firmware to the drive without the key, so with out a backup of the original firmware information then chances are its a new 360.
        Please post as much info as you can
        If using a 360 to power the drive this method can be tricky to accomplish as the 360 likes to
        close the DVD Drive after powering it on.
        You need to power on the drive with the Tray Half Open –To do this using an Xbox 360 as
        Power source, eject the DVD drive and then remove the power lead from the Drive
        Close the tray half way and plug the DVD Drive power cable back into the drive, being VERY
        cautious to ensure the plug is the right way around.
        Using a Connectivity Kit / Xtractor to power the drive
        The easiest way to do this is to simply use the eject button on your connectivity kit to eject the
        drive tray, power off the connectivity kit, push the tray half in and power back on the
        connectivity kit.
        Ok, now we half the half open tray, we navigate to MTKFlash32 tab if you haven’t already.
        If tray status is correct, drive should return good Flash Chip Properties showing status 0x73,
        Drive Properties should show “Drive In Vendor Mode”
        (taken from jf guide)
        • Time2Play
          • Apr 2009
          • 309
          hi thats the thing i didnt event make it to vendor mode it just kept saying benq magic key failed so i turned xbox off turned back on and one light came on with message E65 i didnt even get to reading the key
          • cunny
            • 4915
            You can only try to read it again then if not it does sound like its bricked, witchy might/probably know more so dont loose hope
            • Time2Play
              • Apr 2009
              • 309
              thanks for all your help
              • cunny
                • 4915
                Just DONT ERASE THAT FIRMWARE CHIP UNTIL YOU HAVE A KEY.
                The drive does support bad flash, just findoing out about it now, will report back here
                Do you have the jungleflasher logs?
                • Time2Play
                  • Apr 2009
                  • 309
                  thanks and thanks so mush for helping me
                  • cunny
                    • 4915
                    Use dos flash to see if you can read the firmware and create your orig.bin.
                    All info you need will be in the textbook guide to flashing, not the jungleflasher guide.
                    • Time2Play
                      • Apr 2009
                      • 309
                      hey i searched up and downloaded the textbook guide it only has it about hitatshi drives could u link me please thanks ands thanks for hrlp
                      • cunny
                        • 4915
                        pm me your email address or msn address, i will send it you
