A anonymous source has released the required ecc files needed to retrieve the CPUkey from 360's on dash 15572 and above, release notes below.
"DGX less key retrieval 15572 + dashboards
Fat and Slim
Dubbed DGX R.I.P
////////////readme\\\\\\\\\\\\
There a number of ppl behind this and they shall not be named
Contributions in one way or another from vendors and sources.
You know who you are. Thank You for your efforts in this.
This puts an end to the era we know as the DGX. The product was a good idea
and paid for itself after a few uses however not quick enough for my liking.
Instructions
Dump nand
flash approiate ecc file for your motherboard to nand
wire a REGULAR glitch chip of your choice rgh1/rgh2 as you normally would
retrieve key
done
no hours waiting and messing about with wire config.
Fat and Slim
Dubbed DGX R.I.P
Instructions
Dump nand
retrieve key
done
Team Xecuter has just released their method for retrieving the CPU Key from an xbox 360 console that has been updated to dashboards 15572+. This release seems to have been rushed out the door as recently there have been some ECC files floating around the net that allow the retreval of the CPU Key without the use of the DGX.
Team Xecuter RGX (inc DGX to RGX Conversion)
March 02 2013
A few months ago we brought you DGX (Double Glitch-X) which enable the key retrieval from all slim consoles above dashboard version 15572.
The DGX was the first and only hack able to do this and worked with great success, enabling the scene to continue on with it's homebrew endeavors. For some bizarre reason some outsiders are claiming that DGX was no good and that it was too slow? The fact that there was NOTHING else that could achieve the hack and the fact that there are hundreds and hundreds of pro modders posting their success stories with boot times between 5 and 30 seconds ***8211; I guess that completely went over their heads?
In the last week a leaked bootloader has been passed around by sources who wish to remain anonymous which allows booting without knowing the CPU Key, enabling our DGX method to work with a single glitch (which is how normal RGH works). To use simply flash to the 360 using any RGH board. Naturally you will get the very best results using a CR3 Pro ***8211; or even a converted DGX wink.gif
So this now opens two doors:
1. Compile a solid set of ECC's for standard RGH boards that can recover keys on Phat models Zephyr, Falcon, Jasper ***8211; and slim models Trinity & Corona (Both 16Mb v1/v3 and 4Gb v2/v4). The speed and performance will be no where near as good as the DGX hardware, but it will still work all the same. Much like the DGX, key recovery is a one time process anyway.
2. To design a new hack for the DGX hardware so that it can be converted to what we will now call RGX (Regular Glitch-X). As the DGX hardware has similar parts used by the high performance CR3 Pro, the DGX (RGX) can be used as a regular (or not so in this case) RGH board but much faster and better performance than any other 64 based board. In fact the only board out there that will perform better is the CR3 Pro ***8211; everything else it will just smoke. DGX R.I.P? Sure it is***8230;***8230;
Files Included:
RGX ECC For Zephyr, Falcon, Jasper, Trinity & Corona
DGX to RGX XSVF Updates for Corona (3 Timing Versions)
Much more coming for DGX as well as new J-Runner and new DGX(RGX) Install guides***8230;***8230;.
We see a lot of stores selling the DGX v1.0s quite cheap ***8211; I suggest you grab them while you can
Files Included:
