hi planning gon getting my xbox 360 flashed, i have found someone to do it, what do i need to make sure i do in order NOT to get banned, ie what kind of games, use abgx etc etc? as i had one a few years ago and it got banned after 2 months, so i want to do it this time but do everything right and safe.. help and guides will help thanks edit : what kind of programmes and burners do i need? i seen something called an i has?
flashing xbox
how should I burn, I have a liteon burner model number : eZAU120 is that fine? and also what are some tip snot to get banned etc thanks my fellow man utd fan!haaComment
also you could flash with latest lt firmware i think lt 3.0 was latest but not been online to check lately, once flashed copied games are undetectable on live.
keep a spare drive handy though (same make and model) and use it just to do dash updates then plug back in your flashed drive.
happy days.Comment
hi mate where do I get a drive from are they easy to put in and out is it the hard drive? or something else? cheersalso you could flash with latest lt firmware i think lt 3.0 was latest but not been online to check lately, once flashed copied games are undetectable on live.
happy days.Comment
Burner Max Payload is a prog that allows burners to burn to the end of the disc safely. It may have been intergrated into ImgBurn, you'd have to google it as i aint spoon feeding everything.
You can purchase spare/replacement drives. You would still need to flash your drive information over to it, be it in a stock fw or lt fw. If you cant do it, then sometimes the drive supllier cansigpic
