Hair Dryer Trick Works !!
  • acestu
    • 269
    Hi Guys, I recently had ring of death and purchased a nut and bolt repair kit from fleabay after installing it no joy , after this i heard about the hair dryer trick and blasted both sides of the main board for about ten minutes with a hair dryer on hot, then powered up and it has been perfect ever since..... bizzare
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • victor_ray
    • Oct 2008
    • 106
    Good work, what you have done is a reflow of the solder to get the contacts under the GPU and CPU connecting again since the board has warped under heat. If you pm me your e mail address I have a reflow guide on PDF that you may like to see for future reference.
    • wozzo
      • 198
      Heatgun fix is the best diy fix there is, hairdryer may just about get it hot enough.
