burner?
  • tayyab95
    • Jul 2013
    • 79
    burner?
    what burner would I need to burn games, as I have one from a few year ago a liteon one, but do I need a different one now due to xgd3 or something?thanks
  • adeys
    • Aug 2013
    • 9
    Lite-On IHAS124B-19B BURN MAX CAPACITY DISCS FAST! | eBay. .................hope this helps or look onhttp://c4evaspeaks.com/lite-on-ihas-b-cross-flashable-drive-models-compatible-with-c4eva-ixtreme-burner-max-xgd3-firmware/
    • tayyab95
      • Jul 2013
      • 79
      cheers mate, that's probz the cheapest one ive found!
      • tayyab95
        • Jul 2013
        • 79
        do you think theres any point in flashing if the new xbox is coming out
        • cunny
          • 4915
          Thats your choice, anyway could be sometime before the xbox one is modded
          • tayyab95
            • Jul 2013
            • 79
            cheers mate, that burner is 42 quid, is there any other cheaper ones out there which will work?
            • cunny
              • 4915
              Yep there will be. All you need is1 compatable with c4e burner max payload
              Sent from my GT-I9305 using Tapatalk 4
              • tayyab95
                • Jul 2013
                • 79
                Liteon IHAP122-19 22x Internal IDE DVDRW Black Bare PATA + Software: Amazon.co.uk: Computers & Accessories this will work wont it? if you can check it out for me .. I think I will flash better than spending hundreds on games, are you upgrading to the one.
                • cunny
                  • 4915
                  There is a known comapatable list on c4espeaks and no i wont be i dint play on tbe 360
                  • sattv5
                    • May 2013
                    • 376
                    PC World have the HP DVD1260i which is crossflashable with the BurnerMax Software for under ?20
                    HP DVD1260i Internal SATA DVD Writer Deals | Pcworld
                    • tayyab95
                      • Jul 2013
                      • 79
                      what do you mean its cross flashable, that's cheap im going to purchase, just don't know what you mean by that, cheers
                      • jaaa1976
                        • Oct 2011
                        • 16
                        be aware of this when purchasing to ensure that the version you're getting has the newer "B" chipset.
                        • tayyab95
                          • Jul 2013
                          • 79
                          is that the correct one then> can you find me one cheers
                          • sattv5
                            • May 2013
                            • 376
                            Here's the Instructions you will need. You can check the drive before you buy it from PC World to make sure it is the B revision
                            It was the B revision a couple of months ago that they stocked
