360 Slim, Green dot no pic or sound
  • DAVE466
    • 115
    Hi i have a slim that started freezing so i removed the x-clamp and replaced thermal paste wit arctic silver 5.
    I put it back together tried it and all came back on fine.
    I then turned it off and back on after 5min to double check and it froze at xbox screen so i thought it might have been either bolts too tight or too slack.
    Been fiddling with the tightness of bolts for nearly and hour and still no joy.
    When i turn it on now i get a solid green power light on xbox and on power pack, the screen on tv flickers as if its going to come on but no picture comes on.
    Ive checked all usb ports av port for any bent prongs etc and all are ok
    If i try and sync a controller in xbox lights flash round and when sync button on remote is pressed is flashes to say its synced but does not show 1 green light on xbox and the remote just flashes all 4 lights on and off.
    I've tried different hdmi cables, av cables, tv's and it is still the same.
    Any ideas?
    Thanks in advance.
  • cunny
    • 4915
    Has there been any other mods done on the console other than thermal paste replacement?
    You can rule out a short as the powerpack should turn red if a short is present (bent usb pins etc)
    • DAVE466
      • 115
      No mate not that i'm aware of. The drive seal is still intact so im assuming it aint been opened.
      The strange thing is that it all came after doint it and now i get nothing.
      • cunny
        • 4915
        Xbox-experts.co.uk - Editable Xbox 360 Error code Database / List
        360 Slim Error Code List ? Xbox 360 ? BGA Mods Rework and reballing support forum
        • DAVE466
          • 115
          Yeah i seen both of them websites mate. Ya reckon its a gpu/cou and hana problem.
          • cunny
            • 4915
            Could well be, by reading those threads seems to point in that direction, is there any secondary codes given?
            • DAVE466
              • 115
              If im correct in saying that you get the code the same as you would with a phat?
              Pressing and keeping hold of sync button and press eject?
              Ive tried that and as soon as i press the eject button the tray opens.
              • DAVE466
                • 115
                Just been on the phone to someoneand he thinks it could be the internal 4gb memory or it is the gpu/cpu needing reballing.
                I havnt got another 4gb memory module to try but does anyone know if it should boot without the internal 4gb memory module?
                Ive taken the memory out and tried but its still the same.
                • Cod3waX
                  • 1011
                  try this
                  remove ur fix and try bootin it up without any heatsinks
                  more than likley ur gfx has fried itself
                  using the xclamp fix is very temperamental and should only be doin bolts up finger tight
                  if and when u do get it working be prepared for it to only last a maximum of 6 months
                  • DAVE466
                    • 115
                    tried booting without mate and still get nothing.
                    • cunny
                      • 4915
                      Personally. Think your best over on tx forums m8
                      Sent from my GT-I9305 using Tapatalk 4
