lite on probe
  • daz24c
    • 380
    lite on probe
    hi can sum1 help me please.im tryin to flash a lite on drive but the lite on my probe starts off brite but as im tryin to get it to read the key it goes dull n sumtimes wont lite up much the 1st time i put it in.it lites up brite if i put it in the 1st hole just not the 2nd!its annoyin me now
    it just wont read the key at all!!
    Thank Me If I Help You
  • cunny
    • 4915
    Dummy.bin File From Dvdkey32 And Jungle Flasher - Scenyx Entertainment Community
    Not sure if helps but i had someone reply with this thread when he was going on about this.
    Can you also post all info about the set up you are using, hardware software, drivers installed
    • daz24c
      • 380
      Usin sata card 6421 think it comes up as
      jungle flasher doesnt freeze n can do other drives
      just for sum reason i cant do lite ons!has ne1 got a guide on soldering it so i can get the key if thats gona work!
      • daz24c
        • 380
        usin ck3 probe n ck3 pro aswell
        • cunny
          • 4915
          what drivers are installed, u need a usb driver too.
          Liteon DG-16D2S Firmware Update Tutorial
          Also before u flash it, remove the via drivers from the system 32 folder to aviod the via/liteon freeze in jf
          Also if your using a serial to usb lead then you will also need the drivers for that
          • daz24c
            • 380
            I can flash other drives just not this 1 and it doesnt freeze so im guessin everythings ready to go it just doesnt go wen i ask it to
            y wud the probe lite be bright n then not be brite few seconds into it when im not movin it?
            • daz24c
              • 380
              it just keeps comin up serial data is bad
