Using Ixtreme 1.6
  • acestu
    • 269
    Using Ixtreme 1.6
    Hi Guys, does anybody know the score with ixtreme 1.6, ie do you have to put the special cd in to play all backup games or just old type ones ?
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • cunny
    • 4915
    i dont get what you mean, ixtreme 1.6 is a firmware that allows you to play back up games, but it will not allow you to boot a hybrid game (1 that should be wave 3 but patched to wave 2)
    What is it your trying to do now?
    • acestu
      • 269
      Flash Lite on
      Ok Cunny i have been trying to flash my nephews lite-on , if you remember you gave me your tutorial however i purchased the executer pro kit with ck3 probe,and needed a different tutorial, anyway i found one and flashed the 1.6 but could not get it to play back ups, so i reflashed it with 1.5 last night and it works fine, so i thought it was something to do with the iso that you have to burn, i made one but it made no difference. Maybe it didn't flash 1.6 right, it was a bit confusing because the 1.6 for lite-on from xbins was called 1.6 repacked and when put in the jungle flasher firmware folder it was not recognised even when i had unzipped it, so maybe you have to rename it. I didn't flash untill i had extracted the key a few times which looked good and was the same every time.
      cheers
      Acestu
