xbox
  • briangoo
    • 284
    xbox
    hi all i am wondering can you run 2 xboxs from 1 internet line as my 2 kids want 1 each to play on live thanx
  • cgscott
    • 3513
    Yes this will have to been done through the router. That is the only way this can be done.
    Each box will be given a different IP address.
    You can run as many as your router can take.
    Patience is a virtue.
    • briangoo
      • 284
      as in through the wlan port thanx ?
      • cgscott
        • 3513
        If your on wireless you will need 2 wireless adapters 1 for each xbox. These are quite expensive and i don't find them very good.
        The best way to run the 2 boxes is through hard wire.
        Ethernet cables from the ports on your router to each box.
        • briangoo
          • 284
          my comp is wireless but xbox is by cable with 4 ports coming from the back of the router. thanx 4 the info
          • cgscott
            • 3513
            Thats fine run another cable to the other xbox this will be given a separate ip and you will be able to run both at the same time.
