Liteon Drive Solder R707 done
  • cgscott
    • 3513
    Soldered r707 point.
    Liteon is detected. When i go to dump dummy.bin etc i get the bad sata read error on JF.
    Anyone shed some light on this?
    I thought Jf had this sorted so it was a simple extract?
    And if possible with the solder done i read somewhere you can get the files through dos.
    I may have to try this tomorrow.
    Any help appreciated.
    Patience is a virtue.
  • cgscott
    • 3513
    Thanks for the replies guys
    Managed to fix it.
    Had to make a probe of my own.
    A simple solder of the R707 does no do the job.
    • Old Man
      • Aug 2009
      • 35
      As it happens soldering the two points and using jungle flasher does do the job, i have done two like this with an asus mobo with on board raid.
      Think the tricky part is where you decide half in and half out is with the tray.
      • wwdean
        • Jun 2009
        Was that with the Connectivity Kit
        • cgscott
          • 3513
          in order to achieve a flash you must use a probe. Soldering the point doesn't do the job.
          You must have power from the tx and rx connections.
          • cunny
            • 4915
            Print Page - help with lite-on r707/r708
