Help
  • balllysss
    • Aug 2009
    • 4
    Help
    So far ive been able to get software to burn games but im not sure what i should do as i search i come along many different things and unknown words to me as iso flashing and so on Can any body help me understand what to do next?
  • simonn
    • Aug 2009
    • 54
    Follow Cunnys guide, should help you with any problems!
    • cunny
      • 4915
      well if your struggling to download then i cant say no more
      • cgscott
        • 3513
        An iso is an image of the disc you will eventually have.
        To burn a 360 game you will need software called ImgBurn which can be found here.
        Digital Kaos - Downloads - IMGburn V 2.4.4.0
        You will need dual layer discs to burn the games onto. As the file is much larger than your normal dvd.
        You will also need a Dual layer DVD drive to burn the discs.
        Hope this helps.
        Any more questions feel free to ask.
        Patience is a virtue.
        • balllysss
          • Aug 2009
          • 4
          ive used imgburn and i have got 2 files which do i burn to the disk?
          • balllysss
            • Aug 2009
            • 4
            which file do i use to open the download of cunny?
            • cunny
              • 4915
              Double click to .dvd file to open imgburn, this tell imgburn where to beak layers so its same as original
              • cgscott
                • 3513
                The layer break should be 2084960.
                You can open IMGburn first then burn img to disc.
                If you select the wrong file IMGBurn will correct this for you.
