sammy spoofed as lite-on
  • lawson2009
    • 8
    hello guys
    the sammy in my 360 is spoofed with lite-on firmware!! question is do i need to respoof the sammy or can i just upgrade to ix1.6 ? and which firmware is needed sammy or lite on?
    i didnt flash it the 1sttime
    any help would be greatfull !!
  • jimbojimjay
    • Oct 2008
    • 149
    just dump the drive use that as source then put the 1.6 extreme samsung firmware as target then spoof to target then save to file then flash just treat it as a samsung the spoof puts the key of the lite on in for you that way the console thinks its a lite on in the box
    • lawson2009
      • 8
      thank for the reply will try when i get time
      • cunny
        • 4915
        Sound advice there, if you have problems dunping the firmware, you might be best reading it in dos
        • lawson2009
          • 8
          no problems with the flash all done and thanks again for the advice
