RGH issues- booting errors Resolution not supported/pixelated
  • addy2011
    • Nov 2011
    • 15
    Hi,
    Wierd issue with my Slim RGH, Had it over a year no problem. Boot times were very good- booted up withing 40secs-60secs.
    However last few weeks when booting up somtetimes it can take up to 10-20min , other times it'll boot up quick then go straight off displaying messages such as 'resolution not supported', or sometimes it'll boot up the screen wil get pixelated- the xbox light stays on.
    A few times i'll have it booted up and i'll run a game, then 5min into the game screen will go blank but xbox light stays on.
    When this happens i just power it off and on untill it starts working again. when it does work it stays on as if nothings wrong with it!. i've had it on 8hours at a time when working fine.
    Normally i use it over the weekends only =- i would say probably 16hours a week. except hoildays when it'll be used all through
    My gut feeling is telling me maybe the RGH glitch is wearing off? i hope not as i had it done from someone , don't think he is around anymore.
    i also thought maybe it was hdmi cable or port but i tested that by swapping them with my other xbox.
    My tv is not the culprit as everything else is fine.
  • addy2011
    • Nov 2011
    • 15
    Hello everyone,
    Been doing some digging - and found out that my xbox maybe overheating and that the GPU may need to be reballed.
    As i was trying to get prices i came across people who could do it but since it was an RGH they said no. So i was just going to buy new RGH and in th emeantime open this up and try and clean it up.
    However last weekend i went into FSD settings and messed around with FAN speed settings- it was setto AUTO-which im told is correct setting. Still i changed it to 65% and tested xbox - it stayed on a little longer, but still turned off with same error. So then i increased the FAn speed to 75%, after this xbox started working fine. Its a little noisy but cant notice if ive got volume turned up. Now its been working fine , turns on within 30-50secs and plays fine like it did when i first got it.
    I'm sure i still need to get it fixed properly but in th emeantime it looks like i may have solved the issue for now.
    Just in case someone else has same issue and has no answers maybe they could try this.
    • CustomCars
      • Jul 2015
      • 1248
      That's problem with video scaller, but can depend from GPU too.
      All brand FileService - Custom - remapping company
      POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
      | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
      • addy2011
        • Nov 2011
        • 15
        Hi
        Just an update, I've stopped gaming since xbox 1 came out, was contemplating the xbox 1 but since no hack available didnt bother. As for RGH , i was going to pass it on so decided to have a look at it. I ended up stripping it down and giving it a full clean and also Re-applied thermal paste - since then it has been working fine.
        Doubt it'll get much use but hey...
