You can use imgburn to create one or use notepad. In notepad
gamename.iso
Layerbreak= 1913760
Thats assuming the layerbreak is the same on the new wave3 games, someone will tell you if its not
EDIT: just re read your post. If you use winrar it will join all the files together and give you an iso there will probably be a .dvd file inside. If not see above
sorry off topic. i have used a dvd dl dvd to burn season 1 and 2 of prison break but when i put them in my xbox only some work so do i have to do the same as the xbox games and make a .dvd file thanks 4 any help
No, you don't need to.
Have you tested this DVDs that you have burn in another DVD Player ?? Maybe it is corrupted.
