f'ing 3 red lights
its the other way around for me . did take 5 to 10 to turn on , but when its on its fine . left it on all weekend and its been fine , just turn on again and its started first time ? strangeany information provided is for educational/experimental purposes only.Comment
l was going to send mine back but not going to tho , just installed the rrod fix and started fine .. so l will let u know if its cracked it .. 20 minute job ..Last edited by smirnoff_rules; 2 July, 2008, 20:18.any information provided is for educational/experimental purposes only.Comment
Im sure as most of you know, it is advised to limit such failure is the way the xbox is stored. In it laydown position is probably best in this position if the soldering does get to hot and melt there is less chance it will fall away and cause a break in the connection. Which a common fault for RROD.
Ive always used on of the plastic units to direct airflow more efficently.
Il try and get access to my hotmail at some point and post that tutorial."Imagine i have a blaster ray in my hand"
"But you do have a blaster ray in your hand"
"Well you wont have to test your imagination to much then"Comment
link for tutorial - fix-for-the-3rlod.pdf - RROD fix - BADONGO
It is not my tutorial so i dont take any credit for it."Imagine i have a blaster ray in my hand"
same here . had the labels to send back .. no point if theres a chance of an on lite drive . 4 quid for the kit and its working fine again
just got another of ebay for 45 quid , works for 45 min and then rrod , if the kit works its a spareany information provided is for educational/experimental purposes only.Comment
Is it worth buying a 360 with rrod and doing the xclamp fix?
If so how much should i pay up to for one?
What causes the rrod is it because it has had a mod-chip installed or just a bad design flaw by Microsoft?
I am looking to buy a 360 so just wanted to know which way to go buy one with rrod save a bit of money, but if is going to cause me problems then forget that.
Which is the best machine on the market? I just want it for game play and live (chipped would be an advantage) but can do that myself. Is flea bay the best place to buy one? or are there other sites? Just looking for a bargain.Comment
l paid 45 quid for one this week , the guy said it rrod'ed after 45 minutes .. opened up and its was full of dust and blocking the heatsink ..and an easy hitachi 47 in it too , had its working all weekend and its fine , got a x clamp kit just incase but its fine
happy daysany information provided is for educational/experimental purposes only.Comment
I hope you don't mind me adding this to the topic for 3 red lights, only I thought it might help someone?
I've done all the conversions (x clamp, etc). Added extra cooling but to no avail.
I then looked at the power supply. It was roasting. So I tried the PC power supply method. This cured the 3 red lights. Bit noisier but it works.
I've tried different PC psu's and found the ones with 2 fans work better.
Hope this helps.
Frank.Comment
This is really irratiating to me. Why cant microsoft ensure the quality of there products. They have the highest failure rate among the other consoles.Comment
funny as soon as the weather warms up the rrod starts . make sure your box is off the floor . ie on four lego bricks is good . even see if a fan pointed at the box works . if so it needs a blow outany information provided is for educational/experimental purposes only.Comment
