Saints Row 2 ABGX
  • acestu
    • 269
    Saints Row 2 ABGX
    Hi guys, just wondering if anybody has managed to get saints row 2 through ABGX sucsessfully, i have tried 2 different iso's now and they wont even pass level 3 fix........
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • cgscott
    • 3513
    Depends what ISO you downloaded.
    Always check on the ABGX website to see if the iso you are going to download is checked, patched etc.
    This will save you downloading bad or corrupt rips.
    Patience is a virtue.
    • acestu
      • 269
      thanks cg
      Thanks CG, there is a saints row 2 on the abgx database, but how can you be sure that you are downloading the same one.
      cheers
      Acestu
      • cgscott
        • 3513
        Check the file name. Who ripped it etc.
        Then use Newsleech to find the NZB.
        • acestu
          • 269
          Hi CG, the filename on abgx being just the name of the game or is it the xex/crc number m8
          Acestu
          • cgscott
            • 3513
            Look at the filename. If theres any nuke on a file it will tell you why.
            Bad or corrupt CRC etc.
            ABGX.net
            • acestu
              • 269
              Nuke ?
              Wot you mean "NUKE" CG, anything wrong with it ?
              cheers
              Acestu
              • cgscott
                • 3513
                Yes if it has NUKE next to the filename then it has something wrong. Missing files bad CRC etc.
                Take the filename and enter it into Newzleech.
                This in turn will give you the NZb you are looking for.
                • acestu
                  • 269
                  cheers
                  Thanks CG, just one more thing , if the game passes stealth check in abgx but fails this part because there is no ini file on database is it safe to play the game on xbox live or not ?
                  thanks again
                  Acestu
                  P.S. I have just checked and there are no nukes or warnings on the file that i downloaded m8
                  • cgscott
                    • 3513
                    If the rip you got is on ABGX website and says it is pre stealthed then assume it is good to play.
                    I played Operation flashpoint recently that couldnt be verified online but was noted on ABGX as patched.
