what sata leads do i need to flash any xbox
  • djjwdubz
    • 1011
    does any one no what lead i need for the new xbox or can you use the same one i can get sata ports for 10pound thanks for any help
  • cgscott
    • 3513
    Sata cable can pick up for 99p.
    As for flashing you will need a compatible chipset.
    Patience is a virtue.
    • djjwdubz
      • 1011
      thanks 4 help whats all the names what are compatible with the xbox or would it be better and had a look at it and tell you the name
      • cgscott
        • 3513
        I use a Sata Via 6421 Card. These can be bought on ebay for a small fee. Although i can flash with my onboard NForce as well.
        Google and you will find what chips are compatible.
        Then check the list against you chipset in your pc.
