trouble flashing benq drive with jungleflasher
  • tamgunner
    • 691
    hi guys im trying to flash my benq drive i have it connected to my pc. and in jungle i have under drive properties
    vendor-pbds
    name-vad6038-64390c
    but when i click intro/device id i get device intro failed i have trying to repower the drive but still the same.?
  • cgscott
    • 3513
    Got to be done within 1 second mate. Or at least very quicky.
    Are you using the connectivity kit to power it?
    Patience is a virtue.
    • tamgunner
      • 691
      no im using the xboxes power
      • cgscott
        • 3513
        You.ll have to be quick in powering on and off. Leave the power on the console and pull the plug from the drive itself.
        Dont turn the box on and off.
        • tamgunner
          • 691
          ok i have managed to do it but when i clicked on the outro/ata reset the xbox shut down it verifed ok after i write it. does this mean its worked?
          • cgscott
            • 3513
            Should be mate. If it verified it will be done. If the drive ejects then you've done it.
            • tamgunner
              • 691
              xbox just powered off so im unsure
              • cgscott
                • 3513
                Does the drive eject? If so the flash is done if it was still in into it wouldnt eject.
                • tamgunner
                  • 691
                  the drive ejects as normal wen i power on the xbox.?
                  • cgscott
                    • 3513
                    Then it is flashed properly. As long as you spoofed the key. If it fell over the drive would not eject then it would be a dos job.
                    • tamgunner
                      • 691
                      sounds good im getting a copied game within the next couple of days so will try it and see
