and still wont play wave 4 copys, it comes up with play dvd
got my 360 flashed with 1.6
if u have it flashed with the 1.6 Iextreme firmware then it should play the games unless you burning them wrong
or your using the wrong media
first of all u need the following
1) Winrar
2) Abgx360 (after downloading configure the software)..There is Tutorials available.
3) A good set of Media's ... They have to be DVDR+ DL...
recommeded ones are verbatims and Aone discs
4) IMG burn... which can be downloaded VIA google search
aftter you have all those
you now need to unzip the files using Winrar of your downloaded game
and then run that ISO using ABGX 360 to verfify that the game is fit to be burned... i.e that there is no errors and if you planning to play on XBL then u need to make sure that its stealth patched of course.
And finally after doing the above steps and you feel everything is fine... burn the game at 2X and not higher then that.
regards
unadkat
p.s if you have followed the steps correctly then you should have no problems
if the problem still persist then you should maybe have download the game from a different source other the one u are using
if the above is fine then maybe the problem could be with your console... i.e not being flashed properly.
