rrod fix
  • tamgunner
    • 691
    rrod fix
    hi guys ive read a few guys to repair the rrod and was wondering if i could use rubber washers instead of nylon as i cannot seem to find nylon washers anywhere in glasgow?
  • smirnoff_rules
    • 8603
    i dont use plastic washers at all m8 u dont need too
    • micpuk
      • 53
      You already have another thread open with the same question near enough?!
      As in that thread, go but the Team Xecuter RROD repair chip from mrmodchips.com for ?4.99
      You get everything you need in there.
      HTPC:
      Antec Media Fusion / Windows 7 Media Centre /
      ASUS M4A78-VM 780G / AMD Athlon II x2 250 @ 3.2Ghz / 4.0gb GEIL Black Dragon /
      2x 1TB HDD.
      xbox360:
      120GB - Elite - Lite-on - iXtreme LTv1.1
      PS3
      40gb phat. 3.30fw.
      Nintendo Wii:
      Softmodded 4.1E. NeoGamma R8 Beta 15.
      http://www.micp.co.uk
      • tamgunner
        • 691
        so what should i use?
        • tamgunner
          • 691
          well its not the same question is it!
          • micpuk
            • 53
            Ha, so you've opened a thread asking about 5mm bolts and washers?
            Then a thread asking about nylon washers and plastic alternatives? How is it not the same thread?
            HTPC:
            2x 1TB HDD.
            xbox360:
            PS3
            40gb phat. 3.30fw.
            Nintendo Wii:
            • tamgunner
              • 691
              i need this sorted for tommorow so im not going to do what u suggested and order something online
              • cgscott
                • 3513
                Use metal washers i usualy place 1 underneath motherboard then 2 on top of each screw. The nylons aren't bad but they do tend to shrink with the heat unlike metal washers.
                I also drill through the bottom of the chassis and replace the thermal pads on the chips with new pads.
                Don't get many failures at all.
                You can also cut the grill where the fan is ensuring more air is sucked in. Thus cooling the system more but this can also cause build up of dust if not kept in a ventilated room.
                All in all tam just go for metal washers.
                Patience is a virtue.
                • tamgunner
                  • 691
                  thanks mate i thought they suggested nylon to stop the board shorting or something along those lines.
                  well that will save me a trip only thing i need to do is get two screws out that have damaged heads.
                  • tamgunner
                    • 691
                    does it need to be m5 or can i get away with m4?
                    • tamgunner
                      • 691
                      guys got a problem if taken off the heatsinks cleaned them up and put new heatsink compound on ive put the board on my desk connected the power and av lead switched it on got the 3 lights so ive left it until it gets to two then unplugged it from the mains let it cool for 30 mins switch it back on and still got the 3 lights? any ideas?
                      • cgscott
                        • 3513
                        Try loosen the screws a bit.
                        What repair method did you use?
                        How many washers..type of screws etc?
                        • tamgunner
                          • 691
                          ive followed the one in the sticky thread red ring of death fixes ive just got the bored on my desk with the two cables and the front bit plugged in
                          • cgscott
                            • 3513
                            PM sent Tam.
                            I'll talk you through the fix.
                            • tamgunner
                              • 691
                              thanks mate
