I have located someone who can retrieve the firmware off the PCB. This will inturn make the pcb useless so you will need a new drive. I have sent you a pm m8.
EDIT: Is that the one for the xenon mobo Or is it for any ?
Its a kinda catch 22.
Step 1 get a dump of the nand
Step 2 realise its encrypted and you need the cpu id to decrypt it.
Step 3 figure out you need to use a boot disk to get the cpu id
step 4 realise you cant boot the disk because you dont have the dvd key...
Step 5 curl into the foetal position and weep for a few days (i can confirm this step really works)
In order to obtain the DVD key from the keyvault stored in the nand you already need the DVD key...
Like i said catch 22
Im thinking there might be a way around this that would only work with unbanned consoles (you will need live access to download a tool) but details are lengthy at this point and it might not even be possible.
