Problem with Liteon flashed with ix1.6
  • felix11
    • 151
    A box with a liteon drive I flashed with ix1.6 some weeks ago, and was working with backups for a while has suddenly stopped working. If I put a backup into it, it reads for a min then goes back to 'open tray'.
    I thought about flashing it back to its stock fw then reflashing it, but I have read that you cannot restore a liteon back to stock once it's been flashed.
    Is this correct? any other suggestions?
  • wreksta
    • 13
    hi mate im well in with all these mods
    your problem is simply one of these
    1. your sata lead in 360 is not connected properly try reconnecting or
    2. your laser assembly has slid to the end of the rail simply meaning it has gone past the outer edge of the disc hence why it will not return as it cant read the data that tells i to return open the drive and slide it back to the spinndle then try again
    let us know how it goes
    • cgscott
      • 3513
      Sound like the laser has probably packed in. Nothing wrong with flashing over with 1.6 again and trying that but for it to stop suddenly then the laser prob gone.
      Try sticking a dvd in and see if that plays.
      The liteons are bad for laser burning out.
      Patience is a virtue.
      • felix11
        • 151
        It will play a standard DVD - I tried that initially so I didn't think the laser had actually packed in.
        I'll have a look at the laser assemby and see what I can find - thanks to both of your for your input.
        I will let you know what I find.....
        • felix11
          • 151
          So I had as look and the laser assembly was about half an inch away from the end of the spindle - so I moved it all the way back. But still the same problem.
          It will play a film DVD - but no games, backup or otherwise.
          Any more idea's?
          • cgscott
            • 3513
            Sounds like a reflash might do the job.
            This is what happens to a drive when the key is wrong.
            But if you say it worked before then its a bit strange. Reflash it and it should wotk.
            • felix11
              • 151
              The thought that the key may be wrong was my initial thought. Which is why in my first post I asked about flashing the original firmware back (to restore the correct key), then re-flashing it.
              But I have read you cannot restore a liteon back to stock, is this true? if it isn't, is there a guide anywhere on using jungle flasher to restore stock firmware? (I have the files).
              • cgscott
                • 3513
                If you have the original files stick them into jungleflasher as source and then flash ixtreme 1.6.
                Spoof the key from original over.
                P.S a liteon cannot be restored to original unlike all other drives.
                • wreksta
                  • 13
                  it is true you still can not read liteon firmware if it is flashed or not
                  do you not have the origianal firmware
                  when it was flashed
                  if so you ca re-flash using the key created from your original dummy bin
                  • wreksta
                    • 13
                    if im reading this right i can see you have he ability to flash it again by first obtaining the key with certain tools and probe so it would do it no harm to flash it again
                    but save your dummy.bin and your key as that way you can just load up lite-on ix1.6 insert your key
                    erase drive then flash
                    • wreksta
                      • 13
                      not true idf the key is wrong it will say insert gme into a xbox 360 to play (not open tray sorry though i would point this out)
                      • felix11
                        • 151
                        Thanks for all your help guys but it turns out this is just a troublesome drive - I tried just ejecting and closing the drive tray after I got the 'Open Tray' prompt and the game loaded.
                        It seems that the drive sometimes reads the disc correctly and sometimes not - you just have to try ejecting and reloading till it works.
                        No answer to that I reccon!
                        • Time2Play
                          • Apr 2009
                          • 309
                          sounds lk akey was dodgy allways read the keys about 3 time well i do anyways just reflash and you can flash lite-ons back to stock do it through dos tho
                          SAY THANKS OR JOK WILL TAKE PICTURES OF YOU IN YOUR SLEEP
                          • smirnoff_rules
                            • 8603
                            how do u do this m8 ,, thought u couldnt do this on these ( return to stock )
                            • Time2Play
                              • Apr 2009
                              • 309
                              yes mate aslong as you got your dummy key just run it like a drive recovery iff you need the stuff to do pm me with your email and id be happy to email you the stuff and a guide
