no video output fix
  • tamgunner
    • 691
    no video output fix
    hi guys anyone got info on how to fix no video output on my 360 it starts up fine and i get sound but no picture the lead is fine its the xbox ive had a look on google and stupid sites want you to pay for the guide.
  • djjwdubz
    • 1011
    the video chip has gone you can fix it with the help from you-tube
    if you cant find a video just ask i will find you one
    I'm sure its the same x clamp fix
    • Stevespy
      The new way to fix is using Infra Red
      There are lots of old guides on the Xbox 360, but new methods of repairing the fault are popping up. Turns out the problem is to do with Lead Free solder on the GPU. All the guides you get say to heat the Xbox up, but that doesn't re flow the solder.
      On watchdog they pointed out that the PS3 has the same problem, to do with the graphics chip.
      In a press statement Sony said they used Infra Red BGA rework station to reflow the solder. This is because if you heat the board up to the reflow temperature of the solder, everything would melt.
      You have to heat the board up to 150 c and then use Infra Red to just reheat the areas required to the melting point of the solder.
      There are some interesting videos and information about it on this site:
      Xbox 360 repair Oldham Manchester using Infra Red BGA rework station
      • on_the_jazz
        • 557
        You can reflow using a heatgun (or even an oven if you feel lucky, but tbh if you have trouble with the x-clamp fix better give reflowing a miss!).
        • tamgunner
          • 691
          its cool ive fixed it what i done was i took the xclamps off cleaned the gpu and cpu put new heatsink compound on then i one put one screw in the gpu heatsink and overheated it for 40 mins let it cool and its now working perfected onced it cooled i put in the other 3 screws.
          • on_the_jazz
            • 557
            You might find the rrod returning. Make sure things are cooled better now using 12V mod or some other solution.
            • tamgunner
              • 691
              whats the best heatgun to get power wise?
              • cgscott
                • 3513
                1500-2000 watt heatgun should do.
                Make sure it has variable temp range.
                Patience is a virtue.
                • tamgunner
                  • 691
                  i saw one that had two heat settings and 2 air flow settings. would that do?
                  Titan SF2000XP 2000W Heat Gun 230V - Screwfix.com, Where the Trade Buys
                  • cgscott
                    • 3513
                    You want one with variable temp control.
                    Most start at 80 degrees up to 600.
                    The cheaper guns only come with 2 settings.
                    This is more like it
                    Bosch Hot Air Gun PHG 600-3 1800W, 3165140288347
                    • tamgunner
                      • 691
                      nice one cheers
                      • underbird_gsm
                        • Feb 2010
                        • 16
                        bro no neeed xclamp , its ana chip , reflow the chip , if not work must changed , i fixed this problem exist 2 version ana chip . one smd its easy to replace and bga ana chip , u need bga tech skils , change ... replace ana chip , and alll will be fine
