need help spoofing a hitachi drive
  • funkysy
    • 105
    i have flashed hitachi 47 but it giving me errors and i have a non flashed hitachi 78.
    i have the original 47 F/W, the key and the hack F/W stored
    do i flash the 78 first before i spoof or after?
    is there a tut for this, in detail on here can't seem to find it anywhere.
    or can the 47 be repair?
    would be very gratefully if someone can help
  • cgscott
    • 3513
    Hitachi's are a little different to spoof. Have a read at this.
    Digital Kaos - Downloads - Jungleflasher 1.66 Guide
    The spoofing hitachi is at end of the tutorial.
    Patience is a virtue.
    • funkysy
      • 105
      thanks, i've just looked that the tut and i think i know what to do! only one thing - so i don't need to contect the 47 just plug non flash 78, then flash ix1.51 first and then flash key sector! is that right?
      • cgscott
        • 3513
        Thats it mate. Then it should show as spoofed as 47. Use the 47 orig firmware though with 78 ixtreme.
        • funkysy
          • 105
          thank mate will try later when kids are sleep. if i get stuck i'll get back, hopefully not
          • cgscott
            • 3513
            What errors you getting on the 47 just out of curiosity?
            • funkysy
              • 105
              i'm getting " to play this disc need to put in a xbox 360 console" any idea's
              • cgscott
                • 3513
                You flashed it with the correct key?
                • funkysy
                  • 105
                  well i got box and it had 1 red light, i fixed that then i flash it then find the error when i tested it. so i assume that i have used the right key, how do i find out if the key is right or wrong!!!!!
                  • cgscott
                    • 3513
                    Prob best to spoof the key onto the 78 if you get same results you might find its not been done right in the first place.
                    Does the key look like a normal drive key?
                    • cgscott
                      • 3513
                      Did you get the drive sorted?
                      • funkysy
                        • 105
                        sorry mate i haven't got back to you, i've been working..
                        anyway i haven't try anything yet, mite give it a quick go now
