dual layer coasters
  • thered
    • 4915
    dual layer coasters
    been doing a couple of games for the kids for the xbox i have done them before a while ago but it seems this time they are failing me i dont know why
    they are mirror DL disks the guy in the shop has had no problems with them, the file i am using has been verified by other d/loaders as good i am using imgburn and have tried clonecd but for some reason it wont work
    i have ran it through abgx360 or whatever its called and it seems fine (even though i dont really know what im looking for) anyways any tips for imgburn would be great thanks
  • felix11
    • 151
    What speed are u burning them at? Anything over 2x often results in failures-especially with a 'lower' grade disc like mirror.
    • thered
      • 4915
      i was using 8 then i went to 2.4 i will try 2 now thanks
      i used to use aone or arita both cheapies with no problems when i first did em i bought the purple trax data ones they were very expensive but i was advised to get the best ones so i did then someone told me that the aone were ok so i tried em and they were and they were also half the price too
      • felix11
        • 151
        I have found that any of the 'cheaper' DL disc's tend to produce a few failures. And i find cloneCD works better than imgburn.
        One thought occurs, are you burning from the .dvd file? - if not, you will need to set the layer break manually.
        If the layer break is correct, and you still get failures at 2x, then most likely it is the discs. You could try re-installing cloneCD to ensure it is properly installed, also, maybe clean the heads on your DVD writer.
        • thered
          • 4915
          tried 2x got this
          I 10:29:01 ImgBurn Version 2.5.0.0 started!
          I 10:29:01 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
          I 10:29:01 Total Physical Memory: 2,095,596 KB - Available: 1,018,100 KB
          I 10:29:01 Initialising SPTI...
          I 10:29:01 Searching for SCSI / ATAPI devices...
          I 10:29:04 Found 1 DVD-ROM, 1 DVD?RW and 1 DVD?RW/RAM!
          I 10:43:59 Operation Started!
          I 10:43:59 Source File: C:\Documents and Settings\fergy\My Documents\Downloads\Pro.Evolution.Soccer.2010.PAL. X360-Allstars\all-pes2010.dvd
          I 10:43:59 Source File Sectors: 3,827,488 (MODE1/2048)
          I 10:43:59 Source File Size: 7,838,695,424 bytes
          I 10:43:59 Source File Volume Identifier: DVD_ROM
          I 10:43:59 Source File Volume Set Identifier: 356fc000MS UDFBridge
          I 10:43:59 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
          I 10:43:59 Source File Implementation Identifier: Microsoft CDIMAGE UDF
          I 10:43:59 Source File File System(s): ISO9660, UDF (1.50)
          I 10:43:59 Destination Device: [2:0:0] TSSTcorp CD/DVDW SH-S183L SB01 (F (ATA)
          I 10:43:59 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 4x, 6x, 8x)
          I 10:43:59 Destination Media Sectors: 4,173,824
          I 10:43:59 Write Mode: DVD
          I 10:43:59 Write Type: DAO
          I 10:43:59 Write Speed: 2x
          I 10:43:59 Link Size: Auto
          I 10:43:59 Lock Volume: Yes
          I 10:43:59 Test Mode: No
          I 10:43:59 OPC: No
          I 10:43:59 BURN-Proof: Enabled
          W 10:43:59 Write Speed Miscompare! - Wanted: 2,770 KB/s (2x), Got: 5,540 KB/s (4x)
          I 10:43:59 Book Type Setting: DVD-ROM
          I 10:43:59 User Specified L0 Data Zone Capacity: 1,913,760
          I 10:44:59 Set L0 Data Zone Capacity Succeeded!
          I 10:44:59 Filling Buffer... (40 MB)
          I 10:45:00 Writing LeadIn...
          I 10:45:18 Writing Session 1 of 1... (1 Track, LBA: 0 - 3827487)
          I 10:45:18 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
          I 10:45:18 Writing Layer 0... (LBA: 0 - 1913759)
          I 10:57:05 Writing Layer 1... (LBA: 1913760 - 3827487)
          I 11:09:08 Synchronising Cache...
          I 11:09:10 Closing Track...
          I 11:09:31 Finalising Disc...
          I 11:10:24 Exporting Graph Data...
          I 11:10:24 Graph Data File: C:\Documents and Settings\fergy\Application Data\ImgBurn\Graph Data Files\TSSTcorp_CD-DVDW_SH-S183L_SB01_28-NOVEMBER-2009_10-43_RICOHJPN-D01-67_2x.ibg
          I 11:10:24 Export Successfully Completed!
          I 11:10:24 Operation Successfully Completed! - Duration: 00:26:24
          I 11:10:24 Average Write Rate: 5,356 KB/s (3.9x) - Maximum Write Rate: 5,590 KB/s (4.0x)
          I 11:10:24 Cycling Tray before Verify...
          W 11:10:31 Waiting for device to become ready...
          I 11:11:59 Device Ready!
          I 11:12:00 Operation Started!
          I 11:12:00 Source Device: [2:0:0] TSSTcorp CD/DVDW SH-S183L SB01 (F (ATA)
          I 11:12:00 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67) (Speeds: 4x, 6x, 8x)
          I 11:12:00 Image File: C:\Documents and Settings\fergy\My Documents\Downloads\Pro.Evolution.Soccer.2010.PAL. X360-Allstars\all-pes2010.dvd
          I 11:12:00 Image File Sectors: 3,827,488 (MODE1/2048)
          I 11:12:00 Image File Size: 7,838,695,424 bytes
          I 11:12:00 Image File Volume Identifier: DVD_ROM
          I 11:12:00 Image File Volume Set Identifier: 356fc000MS UDFBridge
          I 11:12:00 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
          I 11:12:00 Image File Implementation Identifier: Microsoft CDIMAGE UDF
          I 11:12:00 Image File File System(s): ISO9660, UDF (1.50)
          I 11:12:00 Read Speed (Data/Audio): MAX / MAX
          I 11:12:00 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3827487)
          I 11:12:00 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
          I 11:12:00 Verifying Layer 0... (LBA: 0 - 1913759)
          I 11:20:16 Verifying Layer 1... (LBA: 1913760 - 3827487)
          W 11:25:36 Failed to Read Sector 2813408 - Reason: Timeout on Logical Unit
          W 11:26:12 Retrying (1)...
          W 11:26:19 Retry Failed - Reason: Timeout on Logical Unit
          W 11:26:20 Retrying (2)...
          I 11:26:21 Verifying Sectors...
          W 11:26:28 Failed to Read Sector 2813457 - Reason: Timeout on Logical Unit
          W 11:26:29 Retrying (1)...
          I 11:26:32 Verifying Sectors...
          W 11:26:40 Miscompare at LBA: 2813457, Offset: 0
          W 11:26:40 Device: 0xF3
          W 11:26:40 Image File: 0xF4
          W 11:26:40 Total Errors in Sector: 2,033
          I 11:26:40 Verifying Sectors...
          W 11:26:42 Miscompare at LBA: 2813458, Offset: 8
          W 11:26:42 Device: 0x87
          W 11:26:42 Image File: 0x30
          W 11:26:42 Total Errors in Sector: 1,656
          I 11:26:42 Verifying Sectors...
          W 11:26:43 Miscompare at LBA: 2813459, Offset: 2
          W 11:26:43 Device: 0x70
          W 11:26:43 Image File: 0x1F
          W 11:26:43 Total Errors in Sector: 1,461
          I 11:26:43 Verifying Sectors...
          W 11:26:44 Miscompare at LBA: 2813460, Offset: 11
          W 11:26:44 Device: 0xBE
          W 11:26:44 Image File: 0xD1
          W 11:26:44 Total Errors in Sector: 1,498
          I 11:26:44 Verifying Sectors...
          W 11:26:44 Miscompare at LBA: 2813461, Offset: 0
          W 11:26:44 Device: 0xF3
          W 11:26:44 Image File: 0xF1
          W 11:26:44 Total Errors in Sector: 2,040
          I 11:26:49 Verifying Sectors...
          W 11:26:49 Miscompare at LBA: 2813462, Offset: 0
          W 11:26:49 Device: 0x3D
          W 11:26:49 Image File: 0x30
          W 11:26:49 Total Errors in Sector: 2,037
          W 11:26:49 Miscompare at LBA: 2813463, Offset: 5
          W 11:26:49 Device: 0xC7
          W 11:26:49 Image File: 0xF3
          W 11:26:49 Total Errors in Sector: 1,607
          W 11:26:49 Miscompare at LBA: 2813464, Offset: 0
          W 11:26:49 Device: 0xAD
          W 11:26:49 Image File: 0xBD
          W 11:26:49 Total Errors in Sector: 1,635
          W 11:26:49 Miscompare at LBA: 2813465, Offset: 0
          W 11:26:49 Device: 0x73
          W 11:26:49 Image File: 0x72
          W 11:26:49 Total Errors in Sector: 2,042
          W 11:26:49 Miscompare at LBA: 2813466, Offset: 0
          W 11:26:49 Device: 0x3C
          W 11:26:49 Image File: 0xC9
          W 11:26:49 Total Errors in Sector: 2,039
          W 11:26:49 Miscompare at LBA: 2813467, Offset: 0
          W 11:26:49 Device: 0x5E
          W 11:26:49 Image File: 0x11
          W 11:26:49 Total Errors in Sector: 1,579
          W 11:26:49 Miscompare at LBA: 2813468, Offset: 1
          W 11:26:49 Device: 0x92
          W 11:26:49 Image File: 0xE1
          W 11:26:49 Total Errors in Sector: 1,095
          W 11:26:49 Miscompare at LBA: 2813469, Offset: 0
          W 11:26:49 Device: 0x10
          W 11:26:49 Image File: 0x06
          W 11:26:49 Total Errors in Sector: 943
          W 11:26:49 Miscompare at LBA: 2813470, Offset: 0
          W 11:26:49 Device: 0x31
          W 11:26:49 Image File: 0x33
          W 11:26:49 Total Errors in Sector: 2,038
          W 11:26:49 Miscompare at LBA: 2813471, Offset: 1
          W 11:26:49 Device: 0x7F
          W 11:26:49 Total Errors in Sector: 1,224
          W 11:26:52 Failed to Read Sector 2813504 - Reason: Timeout on Logical Unit
          W 11:26:54 Retrying (1)...
          W 11:27:01 Retry Failed - Reason: Timeout on Logical Unit
          W 11:27:02 Retrying (2)...
          W 11:27:08 Retry Failed - Reason: Timeout on Logical Unit
          W 11:27:09 Retrying (3)...
          W 11:27:16 Retry Failed - Reason: Timeout on Logical Unit
          W 11:27:17 Retrying (4)...
          I 11:27:19 Verifying Sectors...
          W 11:27:46 Failed to Read Sector 2829008 - Reason: Timeout on Logical Unit
          W 11:27:47 Retrying (1)...
          W 11:27:54 Retry Failed - Reason: Timeout on Logical Unit
          W 11:27:54 Retrying (2)...
          W 11:28:01 Retry Failed - Reason: Timeout on Logical Unit
          W 11:28:02 Retrying (3)...
          W 11:28:08 Retry Failed - Reason: Timeout on Logical Unit
          W 11:28:09 Retrying (4)...
          W 11:28:15 Retry Failed - Reason: Timeout on Logical Unit
          W 11:28:16 Retrying (5)...
          W 11:28:23 Retry Failed - Reason: Timeout on Logical Unit
          W 11:28:23 Retrying (6)...
          I 11:28:25 Verifying Sectors...
          W 11:28:32 Failed to Read Sector 2829056 - Reason: Timeout on Logical Unit
          W 11:28:33 Retrying (1)...
          I 11:28:39 Verifying Sectors...
          W 11:28:52 Failed to Read Sector 2829392 - Reason: Timeout on Logical Unit
          W 11:28:54 Retrying (1)...
          W 11:29:00 Retry Failed - Reason: Timeout on Logical Unit
          W 11:29:01 Retrying (2)...
          W 11:29:08 Retry Failed - Reason: Timeout on Logical Unit
          W 11:29:09 Retrying (3)...
          W 11:29:15 Retry Failed - Reason: Timeout on Logical Unit
          W 11:29:16 Failed to Read Sector 2829392 - Reason: Timeout on Logical Unit
          W 11:29:20 Miscompare at LBA: 2829393, Offset: 1032
          W 11:29:20 Device: 0x9F
          W 11:29:20 Image File: 0x05
          W 11:29:20 Total Errors in Sector: 62
          I 11:29:20 Verifying Sectors...
          W 11:29:20 Miscompare at LBA: 2829394, Offset: 513
          W 11:29:20 Device: 0x8A
          W 11:29:20 Image File: 0x1F
          W 11:29:20 Total Errors in Sector: 317
          W 11:29:20 Miscompare at LBA: 2829395, Offset: 8
          W 11:29:20 Device: 0xB5
          W 11:29:20 Image File: 0xF1
          W 11:29:20 Total Errors in Sector: 230
          W 11:29:20 Miscompare at LBA: 2829396, Offset: 15
          W 11:29:20 Device: 0xCD
          W 11:29:20 Image File: 0xB2
          W 11:29:20 Total Errors in Sector: 175
          W 11:29:20 Miscompare at LBA: 2829397, Offset: 2
          W 11:29:20 Device: 0x16
          W 11:29:20 Image File: 0xE0
          W 11:29:20 Total Errors in Sector: 373
          W 11:29:20 Miscompare at LBA: 2829398, Offset: 3
          W 11:29:20 Device: 0x44
          W 11:29:20 Image File: 0xE3
          W 11:29:20 Total Errors in Sector: 598
          W 11:29:20 Miscompare at LBA: 2829399, Offset: 1
          W 11:29:20 Device: 0xF5
          W 11:29:20 Image File: 0x00
          W 11:29:20 Total Errors in Sector: 420
          W 11:29:20 Miscompare at LBA: 2829400, Offset: 12
          W 11:29:20 Device: 0xED
          W 11:29:20 Image File: 0xB9
          W 11:29:20 Total Errors in Sector: 322
          W 11:29:20 Miscompare at LBA: 2829401, Offset: 0
          W 11:29:20 Device: 0x80
          W 11:29:20 Image File: 0x9C
          W 11:29:20 Total Errors in Sector: 260
          W 11:29:20 Miscompare at LBA: 2829402, Offset: 13
          W 11:29:20 Device: 0xF2
          W 11:29:20 Image File: 0x31
          W 11:29:20 Total Errors in Sector: 492
          W 11:29:20 Miscompare at LBA: 2829403, Offset: 22
          W 11:29:20 Device: 0xA3
          W 11:29:20 Image File: 0x01
          W 11:29:20 Total Errors in Sector: 402
          W 11:29:20 Miscompare at LBA: 2829404, Offset: 185
          W 11:29:20 Device: 0xE8
          W 11:29:20 Image File: 0x21
          W 11:29:20 Total Errors in Sector: 138
          W 11:29:20 Miscompare at LBA: 2829405, Offset: 1024
          W 11:29:20 Device: 0x8C
          W 11:29:20 Image File: 0xD0
          W 11:29:20 Total Errors in Sector: 61
          W 11:29:20 Miscompare at LBA: 2829406, Offset: 162
          W 11:29:20 Device: 0xD4
          W 11:29:20 Image File: 0xFF
          W 11:29:20 Total Errors in Sector: 174
          W 11:29:20 Miscompare at LBA: 2829407, Offset: 237
          W 11:29:20 Device: 0xD1
          W 11:29:20 Image File: 0xE6
          W 11:29:20 Total Errors in Sector: 34
          W 11:29:26 Failed to Read Sector 2829440 - Reason: Timeout on Logical Unit
          W 11:29:28 Failed to Read Sector 2829440 - Reason: Timeout on Logical Unit
          W 11:29:31 Miscompare at LBA: 2829441, Offset: 0
          W 11:29:31 Device: 0xC8
          W 11:29:31 Image File: 0xDF
          W 11:29:31 Total Errors in Sector: 2,039
          I 11:29:31 Verifying Sectors...
          W 11:29:31 Miscompare at LBA: 2829442, Offset: 6
          W 11:29:31 Device: 0x1C
          W 11:29:31 Image File: 0x22
          W 11:29:31 Total Errors in Sector: 1,326
          W 11:29:31 Miscompare at LBA: 2829443, Offset: 1
          W 11:29:31 Device: 0x9E
          W 11:29:31 Image File: 0xA2
          W 11:29:31 Total Errors in Sector: 1,235
          W 11:29:31 Miscompare at LBA: 2829444, Offset: 0
          W 11:29:31 Device: 0x0D
          W 11:29:31 Image File: 0x42
          W 11:29:31 Total Errors in Sector: 1,689
          W 11:29:31 Miscompare at LBA: 2829445, Offset: 0
          W 11:29:31 Device: 0x2B
          W 11:29:31 Image File: 0xFD
          W 11:29:31 Total Errors in Sector: 2,035
          W 11:29:31 Miscompare at LBA: 2829446, Offset: 0
          W 11:29:31 Device: 0x68
          W 11:29:31 Image File: 0x9E
          W 11:29:31 Total Errors in Sector: 2,037
          W 11:29:31 Miscompare at LBA: 2829447, Offset: 0
          W 11:29:31 Device: 0x85
          W 11:29:31 Image File: 0x01
          W 11:29:31 Miscompare at LBA: 2829448, Offset: 0
          W 11:29:31 Device: 0xFB
          W 11:29:31 Total Errors in Sector: 1,577
          W 11:29:31 Miscompare at LBA: 2829449, Offset: 0
          W 11:29:31 Device: 0xB4
          W 11:29:31 Image File: 0xF1
          W 11:29:31 Total Errors in Sector: 1,532
          W 11:29:31 Miscompare at LBA: 2829450, Offset: 0
          W 11:29:31 Device: 0x97
          W 11:29:31 Image File: 0x4E
          W 11:29:31 Total Errors in Sector: 2,042
          W 11:29:31 Miscompare at LBA: 2829451, Offset: 0
          W 11:29:31 Device: 0x84
          W 11:29:31 Image File: 0x33
          W 11:29:31 Total Errors in Sector: 2,036
          W 11:29:31 Miscompare at LBA: 2829452, Offset: 0
          W 11:29:31 Device: 0x0C
          W 11:29:31 Image File: 0x00
          W 11:29:31 Total Errors in Sector: 1,993
          W 11:29:31 Miscompare at LBA: 2829453, Offset: 0
          W 11:29:31 Device: 0xDD
          W 11:29:31 Image File: 0x1C
          W 11:29:31 Total Errors in Sector: 2,041
          W 11:29:31 Miscompare at LBA: 2829454, Offset: 8
          W 11:29:31 Device: 0xD2
          W 11:29:31 Total Errors in Sector: 1,000
          W 11:29:31 Miscompare at LBA: 2829455, Offset: 0
          W 11:29:31 Device: 0x2E
          W 11:29:31 Image File: 0x10
          W 11:29:31 Total Errors in Sector: 2,040
          W 11:29:38 Failed to Read Sector 2829488 - Reason: Timeout on Logical Unit
          W 11:29:39 Failed to Read Sector 2829488 - Reason: Timeout on Logical Unit
          W 11:29:42 Miscompare at LBA: 2829489, Offset: 4
          W 11:29:42 Device: 0x9A
          W 11:29:42 Image File: 0x02
          W 11:29:42 Total Errors in Sector: 548
          I 11:29:42 Verifying Sectors...
          W 11:29:42 Miscompare at LBA: 2829490, Offset: 10
          W 11:29:42 Device: 0xDE
          W 11:29:42 Image File: 0x3F
          W 11:29:42 Total Errors in Sector: 1,008
          W 11:29:42 Miscompare at LBA: 2829491, Offset: 9
          W 11:29:42 Device: 0x3F
          W 11:29:42 Image File: 0x1F
          W 11:29:42 Total Errors in Sector: 898
          W 11:29:42 Miscompare at LBA: 2829492, Offset: 3
          W 11:29:42 Device: 0xBD
          W 11:29:42 Image File: 0xD1
          W 11:29:42 Total Errors in Sector: 767
          W 11:29:42 Miscompare at LBA: 2829493, Offset: 0
          W 11:29:42 Device: 0x42
          W 11:29:42 Image File: 0xF1
          W 11:29:42 Total Errors in Sector: 1,144
          W 11:29:42 Miscompare at LBA: 2829494, Offset: 4
          W 11:29:42 Device: 0x14
          W 11:29:42 Image File: 0x60
          W 11:29:42 Total Errors in Sector: 959
          W 11:29:42 Miscompare at LBA: 2829495, Offset: 10
          W 11:29:42 Device: 0x5F
          W 11:29:42 Image File: 0x21
          W 11:29:42 Total Errors in Sector: 1,150
          W 11:29:42 Miscompare at LBA: 2829496, Offset: 3
          W 11:29:42 Device: 0xB7
          W 11:29:42 Image File: 0x1B
          W 11:29:42 Total Errors in Sector: 1,021
          W 11:29:42 Miscompare at LBA: 2829497, Offset: 7
          W 11:29:42 Device: 0xCD
          W 11:29:42 Image File: 0x01
          W 11:29:42 Total Errors in Sector: 1,110
          W 11:29:42 Miscompare at LBA: 2829498, Offset: 13
          W 11:29:42 Device: 0xE7
          W 11:29:42 Image File: 0x24
          W 11:29:42 Total Errors in Sector: 1,260
          W 11:29:42 Miscompare at LBA: 2829499, Offset: 8
          W 11:29:42 Device: 0x82
          W 11:29:42 Image File: 0xCE
          W 11:29:42 Total Errors in Sector: 799
          W 11:29:42 Miscompare at LBA: 2829500, Offset: 0
          W 11:29:42 Device: 0x48
          W 11:29:42 Image File: 0x9C
          W 11:29:42 Total Errors in Sector: 874
          W 11:29:42 Miscompare at LBA: 2829501, Offset: 1
          W 11:29:42 Device: 0x74
          W 11:29:42 Image File: 0xF0
          W 11:29:42 Total Errors in Sector: 745
          W 11:29:42 Miscompare at LBA: 2829502, Offset: 178
          W 11:29:42 Device: 0x81
          W 11:29:42 Image File: 0x40
          W 11:29:42 Total Errors in Sector: 567
          W 11:29:42 Miscompare at LBA: 2829503, Offset: 3
          W 11:29:42 Device: 0xE4
          W 11:29:42 Image File: 0xF4
          W 11:29:42 Total Errors in Sector: 393
          W 11:29:50 Failed to Read Sector 2829536 - Reason: Timeout on Logical Unit
          W 11:29:51 Failed to Read Sector 2829536 - Reason: Timeout on Logical Unit
          W 11:30:07 Miscompare at LBA: 2829825, Offset: 4
          W 11:30:07 Device: 0x0C
          W 11:30:07 Image File: 0x44
          W 11:30:07 Total Errors in Sector: 403
          I 11:30:07 Verifying Sectors...
          W 11:30:07 Miscompare at LBA: 2829826, Offset: 4
          W 11:30:07 Device: 0x00
          W 11:30:07 Image File: 0xCC
          W 11:30:07 Total Errors in Sector: 640
          W 11:30:07 Miscompare at LBA: 2829827, Offset: 3
          W 11:30:07 Device: 0xFE
          W 11:30:07 Image File: 0x90
          W 11:30:07 Total Errors in Sector: 679
          W 11:30:07 Miscompare at LBA: 2829828, Offset: 7
          W 11:30:07 Device: 0x73
          W 11:30:07 Image File: 0x00
          W 11:30:07 Total Errors in Sector: 771
          W 11:30:07 Miscompare at LBA: 2829829, Offset: 0
          W 11:30:07 Device: 0x20
          W 11:30:07 Total Errors in Sector: 2,037
          W 11:30:07 Miscompare at LBA: 2829830, Offset: 0
          W 11:30:07 Device: 0x9A
          W 11:30:07 Image File: 0xBD
          W 11:30:07 Total Errors in Sector: 2,041
          W 11:30:07 Miscompare at LBA: 2829831, Offset: 13
          W 11:30:07 Device: 0x81
          W 11:30:07 Image File: 0x21
          W 11:30:07 Total Errors in Sector: 1,027
          W 11:30:07 Miscompare at LBA: 2829832, Offset: 1
          W 11:30:07 Device: 0x53
          W 11:30:07 Image File: 0x20
          W 11:30:07 Total Errors in Sector: 1,404
          W 11:30:07 Miscompare at LBA: 2829833, Offset: 0
          W 11:30:07 Device: 0xBF
          W 11:30:07 Image File: 0x93
          W 11:30:07 Total Errors in Sector: 2,039
          W 11:30:07 Miscompare at LBA: 2829834, Offset: 0
          W 11:30:07 Device: 0x58
          W 11:30:07 Image File: 0xA5
          W 11:30:07 Total Errors in Sector: 2,040
          W 11:30:07 Miscompare at LBA: 2829835, Offset: 0
          W 11:30:07 Device: 0xF2
          W 11:30:07 Image File: 0x80
          W 11:30:07 Total Errors in Sector: 1,189
          W 11:30:07 Miscompare at LBA: 2829836, Offset: 0
          W 11:30:07 Device: 0x3C
          W 11:30:07 Image File: 0x2F
          W 11:30:07 Miscompare at LBA: 2829837, Offset: 0
          W 11:30:07 Device: 0x02
          W 11:30:07 Image File: 0xDF
          W 11:30:07 Total Errors in Sector: 1,553
          W 11:30:07 Miscompare at LBA: 2829838, Offset: 0
          W 11:30:07 Device: 0x3F
          W 11:30:07 Image File: 0xD0
          W 11:30:07 Miscompare at LBA: 2829839, Offset: 0
          W 11:30:07 Device: 0x36
          W 11:30:07 Image File: 0xEF
          W 11:30:20 Failed to Read Sector 2829872 - Reason: Timeout on Logical Unit
          W 11:30:22 Failed to Read Sector 2829872 - Reason: Timeout on Logical Unit
          W 11:30:30 Miscompare at LBA: 2829874, Offset: 19
          W 11:30:30 Device: 0x30
          W 11:30:30 Image File: 0xF3
          W 11:30:30 Total Errors in Sector: 1,295
          I 11:30:30 Verifying Sectors...
          W 11:30:30 Miscompare at LBA: 2829875, Offset: 0
          W 11:30:30 Device: 0x3F
          W 11:30:30 Image File: 0x15
          W 11:30:30 Total Errors in Sector: 2,041
          W 11:30:30 Miscompare at LBA: 2829876, Offset: 6
          W 11:30:30 Device: 0x37
          W 11:30:30 Image File: 0x04
          W 11:30:30 Total Errors in Sector: 1,486
          W 11:30:30 Miscompare at LBA: 2829877, Offset: 0
          W 11:30:30 Device: 0x25
          W 11:30:30 Image File: 0x00
          W 11:30:30 Total Errors in Sector: 2,038
          W 11:30:30 Miscompare at LBA: 2829878, Offset: 0
          W 11:30:30 Device: 0x7E
          W 11:30:30 Image File: 0x36
          W 11:30:30 Total Errors in Sector: 2,043
          W 11:30:30 Miscompare at LBA: 2829879, Offset: 0
          W 11:30:30 Device: 0x7D
          W 11:30:30 Image File: 0xCC
          W 11:30:30 Total Errors in Sector: 2,042
          W 11:30:30 Miscompare at LBA: 2829880, Offset: 0
          W 11:30:30 Device: 0x40
          W 11:30:30 Miscompare at LBA: 2829881, Offset: 0
          W 11:30:30 Device: 0x43
          W 11:30:30 Image File: 0xA0
          W 11:30:30 Miscompare at LBA: 2829882, Offset: 11
          W 11:30:30 Device: 0x66
          W 11:30:30 Image File: 0x18
          W 11:30:30 Total Errors in Sector: 2,003
          W 11:30:30 Miscompare at LBA: 2829883, Offset: 0
          W 11:30:30 Device: 0x6C
          W 11:30:30 Image File: 0x45
          W 11:30:30 Miscompare at LBA: 2829884, Offset: 0
          W 11:30:30 Device: 0xDF
          W 11:30:30 Image File: 0x05
          W 11:30:30 Total Errors in Sector: 2,037
          W 11:30:30 Miscompare at LBA: 2829885, Offset: 0
          W 11:30:30 Device: 0x8C
          W 11:30:30 Image File: 0x61
          W 11:30:30 Miscompare at LBA: 2829886, Offset: 0
          W 11:30:30 Device: 0x02
          W 11:30:30 Image File: 0x21
          W 11:30:30 Miscompare at LBA: 2829887, Offset: 0
          W 11:30:30 Device: 0x57
          W 11:30:30 Total Errors in Sector: 2,035
          W 11:30:37 Failed to Read Sector 2829920 - Reason: Timeout on Logical Unit
          W 11:30:40 Miscompare at LBA: 2829921, Offset: 56
          W 11:30:40 Device: 0x40
          W 11:30:40 Image File: 0xFA
          W 11:30:40 Total Errors in Sector: 145
          I 11:30:40 Verifying Sectors...
          W 11:30:40 Miscompare at LBA: 2829922, Offset: 32
          W 11:30:40 Device: 0xC0
          W 11:30:40 Image File: 0x0D
          W 11:30:40 Total Errors in Sector: 426
          W 11:30:40 Miscompare at LBA: 2829923, Offset: 29
          W 11:30:40 Device: 0xFB
          W 11:30:40 Image File: 0x0B
          W 11:30:40 Total Errors in Sector: 187
          W 11:30:40 Miscompare at LBA: 2829924, Offset: 0
          W 11:30:40 Device: 0xEC
          W 11:30:40 Image File: 0xEB
          W 11:30:40 Total Errors in Sector: 2,037
          W 11:30:40 Miscompare at LBA: 2829925, Offset: 27
          W 11:30:40 Device: 0x49
          W 11:30:40 Image File: 0x5C
          W 11:30:40 Total Errors in Sector: 204
          W 11:30:40 Miscompare at LBA: 2829926, Offset: 3
          W 11:30:40 Device: 0xF7
          W 11:30:40 Image File: 0x20
          W 11:30:40 Total Errors in Sector: 458
          W 11:30:40 Miscompare at LBA: 2829927, Offset: 13
          W 11:30:40 Device: 0x88
          W 11:30:40 Image File: 0xF3
          W 11:30:40 Total Errors in Sector: 341
          W 11:30:40 Miscompare at LBA: 2829928, Offset: 38
          W 11:30:40 Device: 0x12
          W 11:30:40 Image File: 0xCC
          W 11:30:40 Total Errors in Sector: 855
          W 11:30:40 Miscompare at LBA: 2829929, Offset: 2
          W 11:30:40 Device: 0x6F
          W 11:30:40 Image File: 0x60
          W 11:30:40 Total Errors in Sector: 584
          W 11:30:40 Miscompare at LBA: 2829930, Offset: 0
          W 11:30:40 Image File: 0xF2
          W 11:30:40 Total Errors in Sector: 2,039
          W 11:30:40 Miscompare at LBA: 2829931, Offset: 27
          W 11:30:40 Device: 0x7F
          W 11:30:40 Image File: 0x3E
          W 11:30:40 Total Errors in Sector: 638
          W 11:30:40 Miscompare at LBA: 2829932, Offset: 6
          W 11:30:40 Device: 0xB2
          W 11:30:40 Image File: 0xC3
          W 11:30:40 Total Errors in Sector: 566
          W 11:30:40 Miscompare at LBA: 2829933, Offset: 0
          W 11:30:40 Device: 0xF4
          W 11:30:40 Total Errors in Sector: 2,042
          W 11:30:40 Miscompare at LBA: 2829934, Offset: 0
          W 11:30:40 Device: 0x23
          W 11:30:40 Image File: 0x15
          I 11:30:41 Verifying Sectors...
          W 11:30:41 Miscompare at LBA: 2829935, Offset: 22
          W 11:30:41 Device: 0x00
          W 11:30:41 Image File: 0x04
          W 11:30:41 Total Errors in Sector: 594
          W 11:30:50 Failed to Read Sector 2829968 - Reason: Timeout on Logical Unit
          W 11:30:54 Miscompare at LBA: 2829969, Offset: 5
          W 11:30:54 Device: 0xF8
          W 11:30:54 Image File: 0x0D
          W 11:30:54 Total Errors in Sector: 1,324
          I 11:30:54 Verifying Sectors...
          W 11:30:54 Miscompare at LBA: 2829970, Offset: 0
          W 11:30:54 Device: 0xB9
          W 11:30:54 Image File: 0xFD
          W 11:30:54 Total Errors in Sector: 1,437
          W 11:30:54 Miscompare at LBA: 2829971, Offset: 6
          W 11:30:54 Device: 0x1B
          W 11:30:54 Image File: 0x04
          W 11:30:54 Total Errors in Sector: 1,626
          W 11:30:54 Miscompare at LBA: 2829972, Offset: 0
          W 11:30:54 Device: 0xFA
          W 11:30:54 Image File: 0x0A
          W 11:30:54 Total Errors in Sector: 2,044
          W 11:30:54 Miscompare at LBA: 2829973, Offset: 0
          W 11:30:54 Device: 0xD3
          W 11:30:54 Image File: 0xE1
          W 11:30:54 Total Errors in Sector: 1,344
          W 11:30:54 Miscompare at LBA: 2829974, Offset: 0
          W 11:30:54 Device: 0x75
          W 11:30:54 Image File: 0x26
          W 11:30:54 Total Errors in Sector: 2,031
          W 11:30:54 Miscompare at LBA: 2829975, Offset: 0
          W 11:30:54 Device: 0x0D
          W 11:30:54 Image File: 0xC6
          W 11:30:54 Total Errors in Sector: 2,041
          W 11:30:54 Miscompare at LBA: 2829976, Offset: 0
          W 11:30:54 Device: 0xFE
          W 11:30:54 Image File: 0x21
          W 11:30:54 Total Errors in Sector: 2,040
          W 11:30:54 Miscompare at LBA: 2829977, Offset: 0
          W 11:30:54 Device: 0x1C
          W 11:30:54 Image File: 0xF1
          W 11:30:54 Miscompare at LBA: 2829978, Offset: 8
          W 11:30:54 Device: 0x70
          W 11:30:54 Image File: 0x01
          W 11:30:54 Total Errors in Sector: 1,624
          W 11:30:54 Miscompare at LBA: 2829979, Offset: 3
          W 11:30:54 Image File: 0xCC
          W 11:30:54 Total Errors in Sector: 1,516
          W 11:30:54 Miscompare at LBA: 2829980, Offset: 0
          W 11:30:54 Device: 0x6F
          W 11:30:54 Image File: 0x66
          W 11:30:54 Total Errors in Sector: 1,692
          W 11:30:54 Miscompare at LBA: 2829981, Offset: 0
          W 11:30:54 Device: 0x44
          W 11:30:54 Image File: 0xE0
          W 11:30:54 Miscompare at LBA: 2829982, Offset: 0
          W 11:30:54 Device: 0xDF
          W 11:30:54 Image File: 0x80
          W 11:30:54 Total Errors in Sector: 2,046
          W 11:30:54 Miscompare at LBA: 2829983, Offset: 0
          W 11:30:54 Device: 0x78
          W 11:30:54 Image File: 0x1B
          W 11:30:54 Total Errors in Sector: 2,037
          W 11:31:01 Failed to Read Sector 2830016 - Reason: Timeout on Logical Unit
          W 11:31:11 Failed to Read Sector 2830020 - Reason: Timeout on Logical Unit
          W 11:31:14 Miscompare at LBA: 2830021, Offset: 16
          W 11:31:14 Device: 0xB2
          W 11:31:14 Image File: 0xF2
          W 11:31:14 Total Errors in Sector: 1,146
          I 11:31:14 Verifying Sectors...
          W 11:31:14 Miscompare at LBA: 2830022, Offset: 6
          W 11:31:14 Device: 0xAB
          W 11:31:14 Image File: 0x24
          W 11:31:14 Total Errors in Sector: 1,800
          W 11:31:14 Miscompare at LBA: 2830023, Offset: 0
          W 11:31:14 Device: 0xFE
          W 11:31:14 Image File: 0x3B
          W 11:31:14 Total Errors in Sector: 2,039
          W 11:31:14 Miscompare at LBA: 2830024, Offset: 19
          W 11:31:14 Device: 0xAA
          W 11:31:14 Image File: 0xD6
          W 11:31:14 Total Errors in Sector: 1,698
          W 11:31:14 Miscompare at LBA: 2830025, Offset: 0
          W 11:31:14 Device: 0xD9
          W 11:31:14 Image File: 0x33
          W 11:31:14 Total Errors in Sector: 2,040
          W 11:31:14 Miscompare at LBA: 2830026, Offset: 0
          W 11:31:14 Device: 0x14
          W 11:31:14 Image File: 0x0E
          W 11:31:14 Total Errors in Sector: 1,715
          W 11:31:14 Miscompare at LBA: 2830027, Offset: 0
          W 11:31:14 Device: 0x29
          W 11:31:14 Image File: 0x80
          W 11:31:14 Total Errors in Sector: 2,042
          W 11:31:14 Miscompare at LBA: 2830028, Offset: 0
          W 11:31:14 Device: 0xBE
          W 11:31:14 Image File: 0x22
          W 11:31:14 Total Errors in Sector: 1,908
          W 11:31:14 Miscompare at LBA: 2830029, Offset: 0
          W 11:31:14 Image File: 0x7D
          W 11:31:14 Total Errors in Sector: 1,748
          W 11:31:14 Miscompare at LBA: 2830030, Offset: 3
          W 11:31:14 Device: 0xBF
          W 11:31:14 Image File: 0x1E
          W 11:31:14 Total Errors in Sector: 1,248
          W 11:31:14 Miscompare at LBA: 2830031, Offset: 0
          W 11:31:14 Device: 0x0E
          W 11:31:14 Image File: 0xED
          W 11:31:14 Total Errors in Sector: 2,043
          W 11:31:26 Miscompare at LBA: 2830066, Offset: 3
          W 11:31:26 Device: 0xE7
          W 11:31:26 Image File: 0x20
          W 11:31:26 Total Errors in Sector: 246
          I 11:31:26 Verifying Sectors...
          W 11:31:26 Miscompare at LBA: 2830067, Offset: 337
          W 11:31:26 Device: 0x4D
          W 11:31:26 Image File: 0xED
          W 11:31:26 Total Errors in Sector: 189
          W 11:31:26 Miscompare at LBA: 2830068, Offset: 1
          W 11:31:26 Device: 0x41
          W 11:31:26 Image File: 0x22
          W 11:31:26 Total Errors in Sector: 233
          W 11:31:26 Miscompare at LBA: 2830069, Offset: 13
          W 11:31:26 Device: 0x8D
          W 11:31:26 Image File: 0x04
          W 11:31:26 Total Errors in Sector: 311
          W 11:31:26 Miscompare at LBA: 2830070, Offset: 14
          W 11:31:26 Device: 0x1D
          W 11:31:26 Image File: 0xEE
          W 11:31:26 Total Errors in Sector: 586
          W 11:31:26 Miscompare at LBA: 2830071, Offset: 0
          W 11:31:26 Device: 0x00
          W 11:31:26 Image File: 0x11
          W 11:31:26 Total Errors in Sector: 2,038
          W 11:31:26 Miscompare at LBA: 2830072, Offset: 7
          W 11:31:26 Device: 0x30
          W 11:31:26 Image File: 0xFF
          W 11:31:26 Total Errors in Sector: 563
          W 11:31:26 Miscompare at LBA: 2830073, Offset: 24
          W 11:31:26 Device: 0x2D
          W 11:31:26 Image File: 0xC6
          W 11:31:26 Total Errors in Sector: 583
          W 11:31:26 Miscompare at LBA: 2830074, Offset: 3
          W 11:31:26 Device: 0xA3
          W 11:31:26 Image File: 0x48
          W 11:31:26 Total Errors in Sector: 698
          W 11:31:26 Miscompare at LBA: 2830075, Offset: 5
          W 11:31:26 Device: 0x98
          W 11:31:26 Image File: 0xCB
          W 11:31:26 Total Errors in Sector: 904
          W 11:31:26 Miscompare at LBA: 2830076, Offset: 23
          W 11:31:26 Device: 0x55
          W 11:31:26 Image File: 0x3B
          W 11:31:26 Total Errors in Sector: 1,100
          W 11:31:27 Miscompare at LBA: 2830077, Offset: 2
          W 11:31:27 Device: 0x34
          W 11:31:27 Image File: 0x19
          W 11:31:27 Total Errors in Sector: 1,117
          I 11:31:27 Verifying Sectors...
          W 11:31:27 Miscompare at LBA: 2830078, Offset: 22
          W 11:31:27 Device: 0x67
          W 11:31:27 Image File: 0x3E
          W 11:31:27 Total Errors in Sector: 796
          W 11:31:27 Miscompare at LBA: 2830079, Offset: 163
          W 11:31:27 Device: 0x25
          W 11:31:27 Image File: 0xEA
          W 11:31:27 Total Errors in Sector: 412
          W 11:31:42 Miscompare at LBA: 2830113, Offset: 3
          W 11:31:42 Device: 0x23
          W 11:31:42 Image File: 0xDD
          W 11:31:42 Total Errors in Sector: 573
          I 11:31:42 Verifying Sectors...
          W 11:31:42 Miscompare at LBA: 2830114, Offset: 23
          W 11:31:42 Device: 0x4E
          W 11:31:42 Image File: 0x00
          W 11:31:42 Total Errors in Sector: 380
          W 11:31:42 Miscompare at LBA: 2830115, Offset: 39
          W 11:31:42 Device: 0x14
          W 11:31:42 Image File: 0xD3
          W 11:31:42 Total Errors in Sector: 337
          W 11:31:42 Miscompare at LBA: 2830116, Offset: 16
          W 11:31:42 Device: 0x57
          W 11:31:42 Image File: 0x3F
          W 11:31:42 Total Errors in Sector: 320
          W 11:31:42 Miscompare at LBA: 2830117, Offset: 0
          W 11:31:42 Device: 0x7F
          W 11:31:42 Image File: 0xFF
          W 11:31:42 Total Errors in Sector: 2,041
          W 11:31:42 Miscompare at LBA: 2830118, Offset: 30
          W 11:31:42 Device: 0xBE
          W 11:31:42 Image File: 0xEF
          W 11:31:42 Total Errors in Sector: 508
          W 11:31:42 Miscompare at LBA: 2830119, Offset: 55
          W 11:31:42 Device: 0xF8
          W 11:31:42 Image File: 0x3D
          W 11:31:42 Total Errors in Sector: 918
          W 11:31:42 Miscompare at LBA: 2830120, Offset: 13
          W 11:31:42 Device: 0x58
          W 11:31:42 Image File: 0xF3
          W 11:31:42 Total Errors in Sector: 779
          W 11:31:42 Miscompare at LBA: 2830121, Offset: 23
          W 11:31:42 Device: 0x20
          W 11:31:42 Total Errors in Sector: 1,172
          W 11:31:42 Miscompare at LBA: 2830122, Offset: 0
          W 11:31:42 Device: 0x9B
          W 11:31:42 Image File: 0xD9
          W 11:31:42 Total Errors in Sector: 1,142
          W 11:31:42 Miscompare at LBA: 2830123, Offset: 1
          W 11:31:42 Device: 0x06
          W 11:31:42 Image File: 0xF0
          W 11:31:42 Total Errors in Sector: 1,076
          W 11:31:42 Miscompare at LBA: 2830124, Offset: 0
          W 11:31:42 Device: 0x92
          W 11:31:42 Image File: 0xD0
          W 11:31:42 Total Errors in Sector: 947
          W 11:31:42 Miscompare at LBA: 2830125, Offset: 4
          W 11:31:42 Device: 0x16
          W 11:31:42 Image File: 0x32
          W 11:31:42 Total Errors in Sector: 1,016
          W 11:31:42 Miscompare at LBA: 2830126, Offset: 0
          W 11:31:42 Device: 0x5D
          W 11:31:42 Image File: 0x37
          W 11:31:42 Total Errors in Sector: 2,040
          W 11:31:42 Miscompare at LBA: 2830127, Offset: 17
          W 11:31:42 Device: 0x05
          W 11:31:42 Image File: 0x21
          W 11:31:42 Total Errors in Sector: 577
          W 11:31:54 Miscompare at LBA: 2830162, Offset: 0
          W 11:31:54 Device: 0x8D
          W 11:31:54 Image File: 0x2A
          W 11:31:54 Total Errors in Sector: 2,043
          I 11:31:54 Verifying Sectors...
          W 11:31:54 Miscompare at LBA: 2830164, Offset: 0
          W 11:31:54 Device: 0xBF
          W 11:31:54 Image File: 0xED
          W 11:31:54 Total Errors in Sector: 2,042
          W 11:31:54 Miscompare at LBA: 2830165, Offset: 0
          W 11:31:54 Device: 0xC2
          W 11:31:54 Image File: 0xF5
          W 11:31:54 Miscompare at LBA: 2830166, Offset: 0
          W 11:31:54 Device: 0xF9
          W 11:31:54 Image File: 0x80
          W 11:31:54 Total Errors in Sector: 2,036
          W 11:31:54 Miscompare at LBA: 2830167, Offset: 0
          W 11:31:54 Device: 0x6E
          W 11:31:54 Image File: 0xEC
          W 11:31:54 Total Errors in Sector: 2,039
          W 11:31:54 Miscompare at LBA: 2830168, Offset: 0
          W 11:31:54 Device: 0x6A
          W 11:31:54 Image File: 0x0B
          W 11:31:54 Total Errors in Sector: 2,040
          W 11:31:54 Miscompare at LBA: 2830169, Offset: 0
          W 11:31:54 Device: 0xD6
          W 11:31:54 Image File: 0x11
          W 11:31:54 Miscompare at LBA: 2830170, Offset: 0
          W 11:31:54 Device: 0xAA
          W 11:31:54 Image File: 0x12
          W 11:31:54 Total Errors in Sector: 2,034
          W 11:31:54 Miscompare at LBA: 2830171, Offset: 0
          W 11:31:54 Device: 0x3D
          W 11:31:54 Image File: 0xE3
          W 11:31:54 Miscompare at LBA: 2830172, Offset: 0
          W 11:31:54 Device: 0x1A
          W 11:31:54 Image File: 0x47
          W 11:31:54 Total Errors in Sector: 2,041
          W 11:31:54 Miscompare at LBA: 2830173, Offset: 0
          W 11:31:54 Device: 0x1F
          W 11:31:54 Miscompare at LBA: 2830174, Offset: 0
          W 11:31:54 Device: 0x02
          W 11:31:54 Image File: 0xCB
          W 11:31:54 Miscompare at LBA: 2830175, Offset: 0
          W 11:31:54 Device: 0x00
          W 11:31:54 Image File: 0x30
          W 11:32:00 Miscompare at LBA: 2830210, Offset: 10
          W 11:32:00 Device: 0xB8
          W 11:32:00 Image File: 0x3F
          W 11:32:00 Total Errors in Sector: 228
          I 11:32:00 Verifying Sectors...
          W 11:32:00 Miscompare at LBA: 2830211, Offset: 15
          W 11:32:00 Device: 0xAF
          W 11:32:00 Image File: 0xEF
          W 11:32:00 Total Errors in Sector: 397
          W 11:32:00 Miscompare at LBA: 2830212, Offset: 6
          W 11:32:00 Device: 0x34
          W 11:32:00 Image File: 0x10
          W 11:32:00 Total Errors in Sector: 231
          W 11:32:00 Miscompare at LBA: 2830213, Offset: 40
          W 11:32:00 Device: 0x6C
          W 11:32:00 Image File: 0x74
          W 11:32:00 Total Errors in Sector: 610
          W 11:32:00 Miscompare at LBA: 2830214, Offset: 20
          W 11:32:00 Device: 0x37
          W 11:32:00 Image File: 0x23
          W 11:32:00 Total Errors in Sector: 381
          W 11:32:00 Miscompare at LBA: 2830215, Offset: 10
          W 11:32:00 Device: 0x4E
          W 11:32:00 Image File: 0x02
          W 11:32:00 Total Errors in Sector: 694
          W 11:32:00 Miscompare at LBA: 2830216, Offset: 12
          W 11:32:00 Device: 0xBE
          W 11:32:00 Image File: 0xFF
          W 11:32:00 Total Errors in Sector: 755
          W 11:32:00 Miscompare at LBA: 2830217, Offset: 55
          W 11:32:00 Device: 0xD8
          W 11:32:00 Image File: 0x6F
          W 11:32:00 Total Errors in Sector: 462
          W 11:32:00 Miscompare at LBA: 2830218, Offset: 0
          W 11:32:00 Device: 0x6E
          W 11:32:00 Total Errors in Sector: 2,039
          W 11:32:00 Miscompare at LBA: 2830219, Offset: 5
          W 11:32:00 Device: 0x06
          W 11:32:00 Image File: 0xD2
          W 11:32:00 Total Errors in Sector: 1,003
          W 11:32:00 Miscompare at LBA: 2830220, Offset: 0
          W 11:32:00 Device: 0x28
          W 11:32:00 Image File: 0x3E
          W 11:32:00 Total Errors in Sector: 1,037
          W 11:32:00 Miscompare at LBA: 2830221, Offset: 0
          W 11:32:00 Device: 0xF0
          W 11:32:00 Image File: 0x40
          W 11:32:00 Total Errors in Sector: 2,043
          W 11:32:00 Miscompare at LBA: 2830222, Offset: 29
          W 11:32:00 Device: 0x2F
          W 11:32:00 Image File: 0xD5
          W 11:32:00 Total Errors in Sector: 1,038
          W 11:32:00 Miscompare at LBA: 2830223, Offset: 6
          W 11:32:00 Device: 0x53
          W 11:32:00 Total Errors in Sector: 811
          W 11:32:19 Miscompare at LBA: 2830260, Offset: 7
          W 11:32:19 Device: 0xA0
          W 11:32:19 Image File: 0x00
          W 11:32:19 Total Errors in Sector: 78
          I 11:32:19 Verifying Sectors...
          W 11:32:19 Miscompare at LBA: 2830261, Offset: 65
          W 11:32:19 Device: 0x3D
          W 11:32:19 Image File: 0x10
          W 11:32:19 Total Errors in Sector: 203
          W 11:32:19 Miscompare at LBA: 2830262, Offset: 0
          W 11:32:19 Device: 0x73
          W 11:32:19 Image File: 0x71
          W 11:32:19 Total Errors in Sector: 2,042
          W 11:32:19 Miscompare at LBA: 2830263, Offset: 1
          W 11:32:19 Device: 0x84
          W 11:32:19 Image File: 0xFC
          W 11:32:19 Total Errors in Sector: 2,035
          W 11:32:19 Miscompare at LBA: 2830264, Offset: 12
          W 11:32:19 Device: 0xDF
          W 11:32:19 Image File: 0xBD
          W 11:32:19 Total Errors in Sector: 464
          W 11:32:19 Miscompare at LBA: 2830265, Offset: 0
          W 11:32:19 Device: 0x30
          W 11:32:19 Image File: 0x11
          W 11:32:19 Total Errors in Sector: 2,043
          W 11:32:19 Miscompare at LBA: 2830266, Offset: 47
          W 11:32:19 Device: 0x12
          W 11:32:19 Image File: 0x5B
          W 11:32:19 Total Errors in Sector: 1,011
          W 11:32:19 Miscompare at LBA: 2830267, Offset: 23
          W 11:32:19 Device: 0x54
          W 11:32:19 Image File: 0xF2
          W 11:32:19 Total Errors in Sector: 896
          W 11:32:19 Miscompare at LBA: 2830268, Offset: 35
          W 11:32:19 Device: 0x07
          W 11:32:19 Image File: 0x12
          W 11:32:19 Total Errors in Sector: 681
          W 11:32:19 Miscompare at LBA: 2830269, Offset: 215
          W 11:32:19 Device: 0xE1
          W 11:32:19 Image File: 0x1F
          W 11:32:19 Total Errors in Sector: 764
          W 11:32:19 Miscompare at LBA: 2830270, Offset: 3
          W 11:32:19 Device: 0xB4
          W 11:32:19 Total Errors in Sector: 648
          W 11:32:19 Miscompare at LBA: 2830271, Offset: 26
          W 11:32:19 Device: 0xA6
          W 11:32:19 Image File: 0x66
          W 11:32:19 Total Errors in Sector: 588
          W 11:32:22 Miscompare at LBA: 2830306, Offset: 9
          W 11:32:22 Device: 0x67
          W 11:32:22 Image File: 0xBF
          W 11:32:22 Total Errors in Sector: 229
          I 11:32:22 Verifying Sectors...
          W 11:32:22 Miscompare at LBA: 2830307, Offset: 0
          W 11:32:22 Device: 0x30
          W 11:32:22 Image File: 0xAA
          W 11:32:22 Total Errors in Sector: 2,042
          W 11:32:22 Miscompare at LBA: 2830308, Offset: 6
          W 11:32:22 Device: 0xC5
          W 11:32:22 Image File: 0xEF
          W 11:32:22 Total Errors in Sector: 282
          W 11:32:22 Miscompare at LBA: 2830309, Offset: 0
          W 11:32:22 Device: 0xDA
          W 11:32:22 Image File: 0xF2
          W 11:32:22 Miscompare at LBA: 2830310, Offset: 0
          W 11:32:22 Device: 0x29
          W 11:32:22 Image File: 0x01
          W 11:32:22 Total Errors in Sector: 2,041
          W 11:32:22 Miscompare at LBA: 2830311, Offset: 9
          W 11:32:22 Device: 0xB2
          W 11:32:22 Image File: 0x41
          W 11:32:22 Total Errors in Sector: 347
          W 11:32:22 Miscompare at LBA: 2830312, Offset: 0
          W 11:32:22 Device: 0x2E
          W 11:32:22 Image File: 0x0E
          W 11:32:22 Total Errors in Sector: 2,037
          W 11:32:22 Miscompare at LBA: 2830313, Offset: 1
          W 11:32:22 Image File: 0xE3
          W 11:32:22 Total Errors in Sector: 428
          W 11:32:22 Miscompare at LBA: 2830314, Offset: 5
          W 11:32:22 Device: 0x0D
          W 11:32:22 Image File: 0x65
          W 11:32:22 Total Errors in Sector: 486
          W 11:32:22 Miscompare at LBA: 2830315, Offset: 0
          W 11:32:22 Device: 0x95
          W 11:32:22 Image File: 0x64
          W 11:32:22 Total Errors in Sector: 2,039
          W 11:32:22 Miscompare at LBA: 2830316, Offset: 3
          W 11:32:22 Device: 0x7F
          W 11:32:22 Image File: 0x03
          W 11:32:22 Total Errors in Sector: 1,150
          W 11:32:22 Miscompare at LBA: 2830317, Offset: 0
          W 11:32:22 Device: 0x2A
          W 11:32:22 Image File: 0x02
          W 11:32:22 Miscompare at LBA: 2830318, Offset: 4
          W 11:32:22 Device: 0x6E
          W 11:32:22 Image File: 0x00
          W 11:32:22 Total Errors in Sector: 1,042
          W 11:32:22 Miscompare at LBA: 2830319, Offset: 24
          W 11:32:22 Device: 0x14
          W 11:32:22 Total Errors in Sector: 390
          W 11:32:35 Failed to Read Sector 2830352 - Reason: Timeout on Logical Unit
          W 11:32:41 Miscompare at LBA: 2830355, Offset: 8
          W 11:32:41 Device: 0x48
          W 11:32:41 Image File: 0x1C
          W 11:32:41 Total Errors in Sector: 599
          I 11:32:41 Verifying Sectors...
          W 11:32:41 Miscompare at LBA: 2830356, Offset: 95
          W 11:32:41 Device: 0x94
          W 11:32:41 Image File: 0xBB
          W 11:32:41 Total Errors in Sector: 529
          W 11:32:41 Miscompare at LBA: 2830357, Offset: 0
          W 11:32:41 Device: 0xB5
          W 11:32:41 Image File: 0xFF
          W 11:32:41 Total Errors in Sector: 395
          W 11:32:41 Miscompare at LBA: 2830358, Offset: 88
          W 11:32:41 Device: 0x06
          W 11:32:41 Image File: 0x02
          W 11:32:41 Total Errors in Sector: 705
          W 11:32:41 Miscompare at LBA: 2830359, Offset: 0
          W 11:32:41 Device: 0x43
          W 11:32:41 Image File: 0xB3
          W 11:32:41 Total Errors in Sector: 592
          W 11:32:41 Miscompare at LBA: 2830360, Offset: 17
          W 11:32:41 Device: 0xB4
          W 11:32:41 Image File: 0x54
          W 11:32:41 Total Errors in Sector: 828
          W 11:32:41 Miscompare at LBA: 2830361, Offset: 19
          W 11:32:41 Device: 0x8C
          W 11:32:41 Image File: 0x9D
          W 11:32:41 Total Errors in Sector: 692
          W 11:32:41 Miscompare at LBA: 2830362, Offset: 55
          W 11:32:41 Device: 0x49
          W 11:32:41 Image File: 0x21
          W 11:32:41 Total Errors in Sector: 597
          W 11:32:41 Miscompare at LBA: 2830363, Offset: 3
          W 11:32:41 Device: 0xC4
          W 11:32:41 Image File: 0xF2
          W 11:32:41 Total Errors in Sector: 1,128
          W 11:32:41 Miscompare at LBA: 2830364, Offset: 30
          W 11:32:41 Total Errors in Sector: 866
          W 11:32:41 Miscompare at LBA: 2830365, Offset: 0
          W 11:32:41 Image File: 0xDD
          W 11:32:41 Total Errors in Sector: 642
          W 11:32:41 Miscompare at LBA: 2830366, Offset: 0
          W 11:32:41 Image File: 0x40
          W 11:32:41 Total Errors in Sector: 2,046
          W 11:32:41 Miscompare at LBA: 2830367, Offset: 11
          W 11:32:41 Device: 0xED
          W 11:32:41 Image File: 0xC0
          W 11:32:41 Total Errors in Sector: 629
          W 11:32:47 Miscompare at LBA: 2830403, Offset: 226
          W 11:32:47 Device: 0x23
          W 11:32:47 Image File: 0x53
          W 11:32:47 Total Errors in Sector: 524
          I 11:32:47 Verifying Sectors...
          W 11:32:47 Miscompare at LBA: 2830404, Offset: 19
          W 11:32:47 Device: 0x2E
          W 11:32:47 Image File: 0x45
          W 11:32:47 Total Errors in Sector: 106
          W 11:32:47 Miscompare at LBA: 2830405, Offset: 25
          W 11:32:47 Device: 0x78
          W 11:32:47 Image File: 0x6D
          W 11:32:47 Total Errors in Sector: 156
          W 11:32:47 Miscompare at LBA: 2830406, Offset: 163
          W 11:32:47 Device: 0x1A
          W 11:32:47 Total Errors in Sector: 373
          W 11:32:47 Miscompare at LBA: 2830407, Offset: 17
          W 11:32:47 Device: 0x49
          W 11:32:47 Image File: 0x97
          W 11:32:47 Total Errors in Sector: 345
          W 11:32:47 Miscompare at LBA: 2830408, Offset: 0
          W 11:32:47 Device: 0x16
          W 11:32:47 Image File: 0x00
          W 11:32:47 Total Errors in Sector: 2,041
          W 11:32:47 Miscompare at LBA: 2830409, Offset: 12
          W 11:32:47 Device: 0xD2
          W 11:32:47 Image File: 0xEF
          W 11:32:47 Total Errors in Sector: 799
          W 11:32:47 Miscompare at LBA: 2830410, Offset: 31
          W 11:32:47 Device: 0x7A
          W 11:32:47 Image File: 0x31
          W 11:32:47 Total Errors in Sector: 490
          W 11:32:47 Miscompare at LBA: 2830411, Offset: 0
          W 11:32:47 Device: 0x36
          W 11:32:47 Image File: 0x26
          W 11:32:47 Total Errors in Sector: 656
          W 11:32:47 Miscompare at LBA: 2830412, Offset: 7
          W 11:32:47 Device: 0x02
          W 11:32:47 Image File: 0x63
          W 11:32:47 Total Errors in Sector: 593
          W 11:32:47 Miscompare at LBA: 2830413, Offset: 0
          W 11:32:47 Device: 0x06
          W 11:32:47 Image File: 0x01
          W 11:32:47 Total Errors in Sector: 2,040
          W 11:32:47 Miscompare at LBA: 2830414, Offset: 10
          W 11:32:47 Device: 0x15
          W 11:32:47 Image File: 0xC3
          W 11:32:47 Total Errors in Sector: 919
          W 11:32:47 Miscompare at LBA: 2830415, Offset: 0
          W 11:32:47 Device: 0x2C
          W 11:32:47 Image File: 0x42
          W 11:33:00 Miscompare at LBA: 2830454, Offset: 6
          W 11:33:00 Device: 0x54
          W 11:33:00 Image File: 0x24
          W 11:33:00 Total Errors in Sector: 1,409
          I 11:33:00 Verifying Sectors...
          W 11:33:00 Miscompare at LBA: 2830455, Offset: 0
          W 11:33:00 Device: 0x7C
          W 11:33:00 Image File: 0x67
          W 11:33:00 Total Errors in Sector: 2,039
          W 11:33:00 Miscompare at LBA: 2830456, Offset: 0
          W 11:33:00 Device: 0x2E
          W 11:33:00 Image File: 0x54
          W 11:33:00 Total Errors in Sector: 2,043
          W 11:33:00 Miscompare at LBA: 2830457, Offset: 0
          W 11:33:00 Device: 0xD5
          W 11:33:00 Image File: 0x2F
          W 11:33:00 Total Errors in Sector: 2,041
          W 11:33:00 Miscompare at LBA: 2830458, Offset: 0
          W 11:33:00 Device: 0xDA
          W 11:33:00 Image File: 0xDF
          W 11:33:00 Miscompare at LBA: 2830459, Offset: 6
          W 11:33:00 Device: 0x3A
          W 11:33:00 Image File: 0x12
          W 11:33:00 Total Errors in Sector: 1,827
          W 11:33:00 Miscompare at LBA: 2830460, Offset: 0
          W 11:33:00 Device: 0x29
          W 11:33:00 Image File: 0x03
          W 11:33:00 Total Errors in Sector: 1,618
          W 11:33:00 Miscompare at LBA: 2830461, Offset: 0
          W 11:33:00 Device: 0x44
          W 11:33:00 Image File: 0x15
          W 11:33:00 Total Errors in Sector: 2,038
          W 11:33:00 Miscompare at LBA: 2830462, Offset: 0
          W 11:33:00 Device: 0xA1
          W 11:33:00 Image File: 0x43
          W 11:33:00 Total Errors in Sector: 2,040
          W 11:33:00 Miscompare at LBA: 2830463, Offset: 0
          W 11:33:00 Device: 0x7B
          W 11:33:00 Image File: 0x31
          W 11:33:30 Failed to Read Sector 2831280 - Reason: Timeout on Logical Unit
          W 11:33:33 Miscompare at LBA: 2831281, Offset: 0
          W 11:33:33 Device: 0xEF
          W 11:33:33 Image File: 0xEE
          W 11:33:33 Total Errors in Sector: 2,036
          I 11:33:33 Verifying Sectors...
          W 11:33:33 Miscompare at LBA: 2831282, Offset: 0
          W 11:33:33 Device: 0x46
          W 11:33:33 Image File: 0xCD
          W 11:33:33 Total Errors in Sector: 1,635
          W 11:33:33 Miscompare at LBA: 2831283, Offset: 0
          W 11:33:33 Device: 0xA1
          W 11:33:33 Image File: 0x80
          W 11:33:33 Total Errors in Sector: 2,040
          W 11:33:33 Miscompare at LBA: 2831284, Offset: 0
          W 11:33:33 Device: 0x5B
          W 11:33:33 Image File: 0x64
          W 11:33:33 Miscompare at LBA: 2831285, Offset: 0
          W 11:33:33 Device: 0x55
          W 11:33:33 Image File: 0x54
          W 11:33:33 Total Errors in Sector: 2,041
          W 11:33:33 Miscompare at LBA: 2831286, Offset: 13
          W 11:33:33 Device: 0xBE
          W 11:33:33 Image File: 0xED
          W 11:33:33 Total Errors in Sector: 1,295
          W 11:33:33 Miscompare at LBA: 2831287, Offset: 0
          W 11:33:33 Device: 0x42
          W 11:33:33 Image File: 0x01
          W 11:33:33 Total Errors in Sector: 2,037
          W 11:33:33 Miscompare at LBA: 2831288, Offset: 11
          W 11:33:33 Device: 0x41
          W 11:33:33 Image File: 0xDC
          W 11:33:33 Total Errors in Sector: 1,083
          W 11:33:33 Miscompare at LBA: 2831289, Offset: 12
          W 11:33:33 Device: 0x11
          W 11:33:33 Image File: 0x14
          W 11:33:33 Total Errors in Sector: 522
          W 11:33:33 Miscompare at LBA: 2831290, Offset: 0
          W 11:33:33 Device: 0xE2
          W 11:33:33 Total Errors in Sector: 675
          W 11:33:33 Miscompare at LBA: 2831291, Offset: 12
          W 11:33:33 Device: 0x95
          W 11:33:33 Image File: 0x55
          W 11:33:33 Total Errors in Sector: 705
          W 11:33:33 Miscompare at LBA: 2831292, Offset: 17
          W 11:33:33 Device: 0xE4
          W 11:33:33 Image File: 0xF5
          W 11:33:33 Total Errors in Sector: 557
          W 11:33:33 Miscompare at LBA: 2831293, Offset: 81
          W 11:33:33 Device: 0xDF
          W 11:33:33 Total Errors in Sector: 415
          W 11:33:33 Miscompare at LBA: 2831294, Offset: 23
          W 11:33:33 Device: 0x4B
          W 11:33:33 Image File: 0xFD
          W 11:33:33 Total Errors in Sector: 401
          W 11:33:33 Miscompare at LBA: 2831295, Offset: 25
          W 11:33:33 Device: 0x89
          W 11:33:33 Total Errors in Sector: 216
          • felix11
            • 151
            Like I said earlier, I find cloneCD works better-I had many problems with imgburn. Can you re-install cloneCD and try again?
            • thered
              • 4915
              im trying again on write speed 4x then i will try clonecd the write speed of these disks is 4x,6x and 8x so maybe a change to 4x will help if not plenty more coasters to come
              • thered
                • 4915
                ffs disk written but wont finalise
                I 11:36:20 ImgBurn Version 2.5.0.0 started!
                I 11:36:20 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
                I 11:36:20 Total Physical Memory: 2,095,596 KB - Available: 1,093,500 KB
                I 11:36:20 Initialising SPTI...
                I 11:36:20 Searching for SCSI / ATAPI devices...
                I 11:36:20 Found 1 DVD-ROM, 1 DVD?RW and 1 DVD?RW/RAM!
                I 11:44:19 Operation Started!
                I 11:44:19 Source File: C:\Documents and Settings\fergy\My Documents\Downloads\Pro.Evolution.Soccer.2010.PAL. X360-Allstars\all-pes2010.dvd
                I 11:44:19 Source File Sectors: 3,827,488 (MODE1/2048)
                I 11:44:19 Source File Size: 7,838,695,424 bytes
                I 11:44:19 Source File Volume Identifier: DVD_ROM
                I 11:44:19 Source File Volume Set Identifier: 356fc000MS UDFBridge
                I 11:44:19 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
                I 11:44:19 Source File Implementation Identifier: Microsoft CDIMAGE UDF
                I 11:44:19 Source File File System(s): ISO9660, UDF (1.50)
                I 11:44:19 Destination Device: [2:0:0] TSSTcorp CD/DVDW SH-S183L SB01 (F (ATA)
                I 11:44:19 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 4x, 6x, 8x)
                I 11:44:19 Destination Media Sectors: 4,173,824
                I 11:44:19 Write Mode: DVD
                I 11:44:19 Write Type: DAO
                I 11:44:19 Write Speed: 4x
                I 11:44:19 Link Size: Auto
                I 11:44:19 Lock Volume: Yes
                I 11:44:19 Test Mode: No
                I 11:44:19 OPC: No
                I 11:44:19 BURN-Proof: Enabled
                I 11:44:19 Book Type Setting: DVD-ROM
                I 11:44:19 User Specified L0 Data Zone Capacity: 1,913,760
                I 11:45:16 Set L0 Data Zone Capacity Succeeded!
                I 11:45:16 Filling Buffer... (40 MB)
                I 11:45:17 Writing LeadIn...
                I 11:45:38 Writing Session 1 of 1... (1 Track, LBA: 0 - 3827487)
                I 11:45:38 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
                I 11:45:38 Writing Layer 0... (LBA: 0 - 1913759)
                I 11:57:25 Writing Layer 1... (LBA: 1913760 - 3827487)
                I 12:09:28 Synchronising Cache...
                I 12:09:37 Closing Track...
                W 12:10:12 Potential 'WaitImmediateIO' Deferred Error - (0%, 0/3) - Program Memory Area Update Failure
                W 12:10:12 Close Track Failed! - Reason: Program Memory Area Update Failure
                W 12:10:12 Retrying (1 of 3)...
                I 12:10:13 Finalising Disc...
                W 12:11:13 Potential 'WaitImmediateIO' Deferred Error - (0%, 0/3) - Session Fixation Error Writing Lead In
                W 12:11:13 Finalise Disc Failed! - Reason: Session Fixation Error Writing Lead In
                W 12:11:13 Retrying (1 of 3)...
                W 12:12:05 Potential 'WaitImmediateIO' Deferred Error - (77%, 0/3) - Session Fixation Error Writing Lead In
                W 12:12:05 Retry Failed - Reason: Session Fixation Error Writing Lead In
                W 12:12:05 Retrying (2 of 3)...
                W 12:12:23 Potential 'WaitImmediateIO' Deferred Error - (77%, 0/3) - Session Fixation Error Writing Lead In
                W 12:12:23 Retry Failed - Reason: Session Fixation Error Writing Lead In
                W 12:12:23 Retrying (3 of 3)...
                W 12:13:35 Potential 'WaitImmediateIO' Deferred Error - (77%, 0/3) - Session Fixation Error Writing Lead In
                W 12:13:35 Retry Failed - Reason: Session Fixation Error Writing Lead In
                W 12:13:40 Retrying (4)...
                • ezzda1
                  • 172
                  thats the disks matey, try different ones I have the same writer they are funny with some of the cheap media like tuffdisk and mirrors, I always use verbs and never had a bad burn. you could have a look for new fw for your drive (google samsung odd live update and get it from the samsung site) but i think you're on the latest one.
                  • thered
                    • 4915
                    ~~~~ me 1 good burn in 7 but i dont think its ma disks if i use my dupelicator with the same discs i get 3 out of 3 working copies
                    • alunfennell
                      • Oct 2008
                      • 1525
                      Hi thered,
                      I use Verbatim Disks they are the best (They do cost a bit more) I never had one fail with them Ever ! The INK or DYE used to make the disks is what you are paying for Verbatim use a superior DYE to nearly any other manufacturer, I am sure you already know this anyway ?
                      Verbatim are the closest to a original disk used in the manufacturing and publishing by Game company hence the price and surprisingly good results.
                      **The Worlds Best Interactive F1 Strategy Game**
                      • djjwdubz
                        • 1011
                        i was burning them at 6 speed b4 and a few of them messed up but not much.
                        when i 1st started burning my xbox games the man who done my xbox 4 me told me to not burn at full so i knocked it down to 6 speed.
                        now i burn at 2.4 speed and some games freeze for 3 sec i think its the dvd not sure
                        • djjwdubz
                          • 1011
                          • thered
                            • 4915
                            wtf
                            vertabim dual layer yes affirmitive
                            updated driver firmware yes captain
                            burn with imgburn youd better believe it
                            have i got coasters too ~~~~ing right expensive ones at that
                            3 out of 3 ~~~~~ ups using vertabim dl any help please i cant afford anymore
                            I 13:41:07 Searching for SCSI / ATAPI devices...
                            I 13:41:10 Found 1 DVD-ROM, 1 DVD?RW and 1 DVD?RW/RAM!
                            I 13:45:33 Operation Started!
                            I 13:45:33 Source File: C:\Documents and Settings\fergy\My Documents\Downloads\Pro.Evolution.Soccer.2010.PAL. X360-Allstars\all-pes2010.dvd
                            I 13:45:33 Source File Sectors: 3,827,488 (MODE1/2048)
                            I 13:45:33 Source File Size: 7,838,695,424 bytes
                            I 13:45:33 Source File Volume Identifier: DVD_ROM
                            I 13:45:33 Source File Volume Set Identifier: 356fc000MS UDFBridge
                            I 13:45:33 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
                            I 13:45:33 Source File Implementation Identifier: Microsoft CDIMAGE UDF
                            I 13:45:33 Source File File System(s): ISO9660, UDF (1.50)
                            I 13:45:33 Destination Device: [2:0:0] TSSTcorp CD/DVDW SH-S183L SB03 (F (ATA)
                            I 13:45:33 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 4x, 6x, 8x)
                            I 13:45:33 Destination Media Sectors: 4,173,824
                            I 13:45:33 Write Mode: DVD
                            I 13:45:33 Write Type: DAO
                            I 13:45:33 Write Speed: MAX
                            I 13:45:33 Link Size: Auto
                            I 13:45:33 Lock Volume: Yes
                            I 13:45:33 Test Mode: No
                            I 13:45:33 OPC: No
                            I 13:45:33 BURN-Proof: Enabled
                            I 13:45:33 Book Type Setting: DVD-ROM
                            I 13:45:33 Optimal L0 Data Zone Capacity: 1,913,760
                            I 13:45:33 Optimal L0 Data Zone Method: Copied From Original Disc
                            I 13:46:23 Set L0 Data Zone Capacity Succeeded!
                            I 13:46:24 Filling Buffer... (40 MB)
                            I 13:46:24 Writing LeadIn...
                            I 13:46:48 Writing Session 1 of 1... (1 Track, LBA: 0 - 3827487)
                            I 13:46:48 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
                            I 13:46:48 Writing Layer 0... (LBA: 0 - 1913759)
                            I 13:55:01 Writing Layer 1... (LBA: 1913760 - 3827487)
                            I 14:03:45 Synchronising Cache...
                            I 14:03:47 Closing Track...
                            I 14:03:49 Finalising Disc...
                            I 14:04:19 Exporting Graph Data...
                            I 14:04:19 Graph Data File: C:\Documents and Settings\fergy\Application Data\ImgBurn\Graph Data Files\TSSTcorp_CD-DVDW_SH-S183L_SB03_10-DECEMBER-2009_13-45_MKM-003-00_MAX.ibg
                            I 14:04:19 Export Successfully Completed!
                            I 14:04:19 Operation Successfully Completed! - Duration: 00:18:45
                            I 14:04:19 Average Write Rate: 7,534 KB/s (5.4x) - Maximum Write Rate: 11,158 KB/s (8.1x)
                            I 14:04:19 Cycling Tray before Verify...
                            W 14:04:28 Waiting for device to become ready...
                            I 14:04:49 Device Ready!
                            I 14:04:49 Operation Started!
                            I 14:04:49 Source Device: [2:0:0] TSSTcorp CD/DVDW SH-S183L SB03 (F (ATA)
                            I 14:04:49 Source Media Type: DVD+R DL (Book Type: DVD+R DL) (Disc ID: MKM-003-00) (Speeds: 4x, 6x, 8x)
                            I 14:04:49 Image File: C:\Documents and Settings\fergy\My Documents\Downloads\Pro.Evolution.Soccer.2010.PAL. X360-Allstars\all-pes2010.dvd
                            I 14:04:49 Image File Sectors: 3,827,488 (MODE1/2048)
                            I 14:04:49 Image File Size: 7,838,695,424 bytes
                            I 14:04:49 Image File Volume Identifier: DVD_ROM
                            I 14:04:49 Image File Volume Set Identifier: 356fc000MS UDFBridge
                            I 14:04:49 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
                            I 14:04:49 Image File Implementation Identifier: Microsoft CDIMAGE UDF
                            I 14:04:49 Image File File System(s): ISO9660, UDF (1.50)
                            I 14:04:49 Read Speed (Data/Audio): MAX / MAX
                            E 14:04:49 Session 1, Track 1 is smaller on the disc than it is in the image file.
                            E 14:04:49 Disc's Track Sectors: 0 (TOC Sectors: 0)
                            E 14:04:49 Image File's Track Sectors: 3827488 (TOC Sectors: 3827488)
                            E 14:04:50 Operation Failed! - Duration: 00:00:00
                            I 14:04:50 Average Verify Rate: N/A - Maximum Verify Rate: N/A
                            • cgscott
                              • 3513
                              Only your verify thats failed mate.
                              Check the disk in the xbox?
                              I never verify with IMGburn.
                              Always untick it. After finilize disk i get the we jingle that says its good.
                              Patience is a virtue.
