alternatives to img burn
  • johnboy1974
    • 3418
    im having a lot of trouble getting img burn to finalise my discs. im using verbatim dvd+r dl discs.it keeps saying the following after retrying about 6 times.
    W 21:54:00 Close Track Failed! - Reason: Program Memory Area Update Failure.
    ive tried uninstalling img burn and then reinstaling it but no joy
    does anyone know what the problem is and is there an alternative to img burn that is easy to use. many thanks
  • cgscott
    • 3513
    Digital Kaos - Downloads - IMGburn V 2.4.4.0
    Try that version of IMG.
    What make is your dvd writer?
    Patience is a virtue.
    • djjwdubz
      • 1011
      is your verify box ticked
      not sure if this will work but go on to your img burn settings click write then un tick dvd+r finalise disc.
      make sure your burning the .dvd file not the iso
      please let me no if you get it working
      hope i helped
      • johnboy1974
        • 3418
        its a tsst corp internal drive ive been using it for ages with no problems till recently
        its burning dvd+r's movies no problems im beggining to wonder if the drive is faulty.
        • cgscott
          • 3513
          hope i helped
          Do not untick this as you will not know if you have bad burn and will be dissapointed when you stick it in the 360.
          The whole reason IMGburn has this in its program is to let you know its good. If its not you will get the bad burn voice saying OHHH NO.
          I have only had a few failures over maybe 600 disks and this may be my own doing as i tend to rip as well as burn at the same time with my other drives.
          • johnboy1974
            • 3418
            hope i helped
            will give it a try mate but im definitly burning the .dvd file i even deleted the original .dvd file that came with the download and went with the one abgx created but its same problem, as i said i burned plenty in the past with no problems its just cropped up now
            • johnboy1974
              • 3418
              ok im using img burn version 2.5.0.0 and thinking of trying older version but cant get your link its comming up dead.
              right now im trying optimal layer break setting as suggested earlier.
              • delv
                • 22
                I had this problem,What i do is remove the dvd file,then run the program through abgx360 this gives you a new dvd file then i burn them with CloneCD
                • djjwdubz
                  • 1011
                  have you tried it. i have not tried cuz i have had no probs good job u stopped him b4 he messes up another dvd dl.
                  • johnboy1974
                    • 3418
                    it was worth a try but unfortunately it didnt work and i messed up another disc but no worries its just one of about 6 thats been messed up because of this fault, somone suggested clone dvd so i will give it a try thanks anyway for your suggestion it was well worth a try.
