There have been several news reports on Xboxhacker.net of users having success in dumping the keys of the newest un-moddable Liteon DVD drives. The methods posted so far are not for the beginner so do so at your own risk. The method seem crude at the moment, no doubt some easier methods will surface shortly. Remember with that DVD key you can install any flash-able DVD drive to that once un-moddable Xbox 360. Good job to all involved !
-Lift pin 101 and 122 (The MT Chip)
-solder a cable to pin 100, pin 101 and one to 3,3V
-use a 2-way switch which either connects 101 to 3,3V or to 100
-put the switch into the position so that it connects 100 to 101
-power drive
-start Dosflash, it will recognise the SPI with Status x72
-if you read it out now, it will just give you a .bin full of FFFFFFFF, but thats OK, this is how we tricked the Flash Controller to think the SPI is empty
-put the switch in the other position (so that 101 is connected to 3,3V)
-now read the flash
Info from good source.
-power drive
-now read the flash
