Was trying to update my 1.5 firnware to 1.6 on liteon drive , musing junglefalsher , made a mistake , lost firmware , also green light no longer lights up when tochong 707 point , so it does not dump no more , think board is faulty , is their any other way I can flash drive , junglefalsher still sees drive , I managed to try the dos method , but it fails . any ideas please ?
Lost firmware / ck3 faulty
If JF is still seing the drive then you couldnt have erased it. Use the Dummy from Ixtreme tab in jungleflasher to read the drive and it should pull the info you need.
Then reflash the drive with the latest firmware.sigpic
Patience is a virtue.Comment
If you have erased the drive and you dont have the key then you have a brick mate.Comment
