switching dvd drives
  • antone
    managed to flash my liteon but no power to drive now, its well knackered, what id like to know is can i switch the liteon drive for a ben q drive, i do have all the information for liteon ?, cheers in advance
  • cunny
    • 4915
    Yeah just load the orig.bin into jf then load the ixtreme 1.61 benq and flash the benw. It should show up as spoofed as a liteon on the firmware 32 tab
    • frickerd
      • 62
      just a shot in the dark your liton drive did you l-o-eras it in dos? as if jf crash or some error happens you drive seems dead but it aint.
      • showstopper
        • 64
        Try this method first mate - http://www.digital-kaos.co.uk/forums...liteons-55448/
        EDIT - New link from Time2Play
        • cgscott
          • 3513
          Why would you post to another forum.
          All the info he needs is here.
          Patience is a virtue.
          • Time2Play
            • Apr 2009
            • 309
            sounds like a simple brck mate which is simple to recover by all means inbox me if fu need the stuff to unbrick your xbox ill be happy to walk you through it aswell
            SAY THANKS OR JOK WILL TAKE PICTURES OF YOU IN YOUR SLEEP
            • showstopper
              • 64
              Sorry fairly new to this forum.
              If you know the fix could you post it then i will remove my post.
              Just trying to help.
              • Time2Play
                • Apr 2009
                • 309
                hey showstopper im sure are greatful for your help but always search here
                • showstopper
                  • 64
                  Post edited.
                  Cheers.
                  • cunny
                    • 4915
                    Time2play got the info off me.
                    There is a guide on here that tells you how to recover drives. (sammy/benq/liteon).
                    I will see if i can find it, but if you follow the liteon in jungleflasher + dos 1, follow the flashing part then it will recover the drive for you if it just a brick.
