It's a PCI Via VT6421A card which I used to use with Windows XP, Is there such a thing as a 64 bit version of this card for Flashing under Windows 7 64 bit then?
Its the driver that will be made for x64 software. Thing is as stated in this thread and others, you dont need the driver installed for a VIA card anymore thanks to the big improvements made to port io driver that is also now compatable with x64 operating systems. Also removing the driver aviods the freezing issues with the liteon drives.
