recycle original xbox hardware in pc---help!!!!!!
  • kaisar1
    • Aug 2009
    • 462
    hi, i need some advice on whether or not original xbox components will work in my desktop pc?????
    the 2 components which i want to reuse are:
    xbox samsung DVD-ROM Drive Model: SDG-605
    xbox western digital ide hardrive
    also is there any other components that i could recycle and use in my pc?????????
    any advice would be much appreciated. thanks in advance
  • cunny
    • 4915
    yeah the hard drive should be fine once re partitioned
    • kaisar1
      • Aug 2009
      • 462
      is there any password etc or do i just plug and play the hard drive? also this would be my second hard drive in the computer, would i need to make one of the hard drive "slave" or something?
      bit confused, hope you can help
      • andy1weir
        • 363
        youd have to set the hard drive with your os to a master drive then set the xbox hard drive as a slave
        • kaisar1
          • Aug 2009
          • 462
          how do i do that?
          just found out how to do it, thanks,
          one more thing can i reuse the dvd drive as well?????????????
          • snagga
            • 167
            Look here [ame=http://www.youtube.com/watch?v=BvvM2Ao4Jpk]YouTube - Install a Second IDE Hard Drive[/ame]
            • andy1weir
              • 363
              just the same procedure mate, set the xbox dvd drive to a slave and the one you already have in it to master and all should be ok
              the drives in xbox's (as far as im aware) are just standard dvd-rom drives, i know for a fact that you can use a drive from your pc into the xbox so should work vice versa
              good luck
              • chroma
                • 1976
                The only difference between xbox dvd drives and commercial pc drives is the power connector.
                If i remember rightly the xbox has a rectangular feed instead of a standard molex, to get around this you would need to figure the pinouts and patch the connector inside the xbox to a female molex plug to allow it to get power.
                He who laughs last thinks slowest.
                • andy1weir
                  • 363
                  oooh thanks for the info chroma i though they were all the same
