iXtreme LT SS Angle response
  • chroma
    • 1976
    Caution: This SS contains a value (angle 359) that will cause older versions of iXtreme to return a detectable bad response! Make sure your drive is flashed with iXtreme version 1.4 or newer. Alternatively, you may enable the option to adjust angle 359 for compatibility with iXtreme < v1.4
    Ok, so before 1.4 this was bad because the firmware did not perform stealth checks...
    Now ive heard that LT has dropped stealthing too, so the question is would it be "safe" to run a disk with a 359? angle on a drive flashed with LT?
    Would i need to patch it? (if so i can just rip the disk again and see if it returns a different result)
    I just want to know how much of a problem this is before i even begin to bother with downloaded images where i would need to begin to modify images to compensate.
    He who laughs last thinks slowest.
  • wozzo
    • 198
    Yes let ABGX fix the bad angle, iXtreme would give back the correct response anyway but LT wont, so its needed now more than before.
    • cunny
      • 4915
      Yes this was from the days of IX 1.4 before C4 changed his angle. Let abgx fix it or you can manually patch the image in ABGX. SS Versions are also important for live with LT from what i was hearing, Hence the post donw here.
