wireless rapid fire mess up please help
  • djjwdubz
    • 1011
    hello i have been trying to mod my controller but now its messed up the pad it just keeps spinning on the screen. i got the kit from egay yeah thats right i call it egay all programed up can any one try help don't matter if you cant i will just put it in the bin if no one can help. thanks for any help
    p.s the reason i call it egay is cuz everything i got from there is just messed up like a gay. eg the chip programed,solder tips & un programed chip them all no good to me.
    off topic, i hate gays
  • djjwdubz
    • 1011
    ebay will never be used by me again
    • cgscott
      • 3513
      Sorry to hear that mate. Any mod i have got of egay have been fine.
      Think its down to the person who installs them to be honest.
      Check the egay account from whom you got it from and see if anyone else has left bad feedback.
      Dont chuck it in the bin..Send me it. My lad would love a rapid fire controller for his xbox 360.
      Patience is a virtue.
      • wozzo
        • 198
        Or how about you tried to do something well out of your league and ****ed it up.
        Your not a modding pro cause you live on this forum.
        • djjwdubz
          • 1011
          you can have the chip but the controller is messed up now.
          • djjwdubz
            • 1011
            err nah. like i said the tips i got from ebay are crap. the solder just rolls off.
            • chroma
              • 1976
              Then your using too much solder
              simple tip.
              Get the smallest tip for the iron you can possibly find.
              Tin everything first (tinning is getting a bead on the bit and then running any wire/part through that to coat it with solder)
              Once everything is nice and tinned, clean up the contact your going to be soldering to (i generaly use acetone to make sure its spotless) then just slap the tinned wire/part onto the contact and apply heat with a clean bit.
              Then run a continuity and resistance test to ensure the contact is solid, if it looks sketchy then i simply reheat with a wet bit and apply a miniscule ammount of solder.
              saves stripping the traces from the board (a result of too much heat for too long whilst your mucking around trying to fix a cock up) or getting too much solder and causing a short between traces
              If it looks like i applied too much solder then i just quickly reheat and use a desolder pump to remove the excess and do another continuity test to make sure its bombproof.
              He who laughs last thinks slowest.
              • TheRandomLemon
                • Sep 2009
                • 12
                I just bought a third party one. You can get them from pretty much anywhere. They are called Datel Wildfire controllers. Wireless or Wired. Black or White. around ?15 - ?20. great aswell
                When life hands you lemons, grab them, climb up into a tree and start sucking!
                • .: JaCkPoT :.
                  Retired Sat TV Addict
                  • Aug 2008
                  • 5607
                  Not being funny, when i was 14 ( several months back ) i use to do rapidfire myself, soldering can be easy or hard, depends on how you solder.
                  i have done about 7 controllers, sold a few on eBay, done a few for mates and the controllers in my house and only one has ever been returned to me and that was 8 weeks after i sold it so the other person must have dropped it. I used a ?5 soldering iron and it works fine..
                  Your controller wont be messed up, somewhere along the lines solder has fallen and bridged two points in the controller.
                  ___________________
                  In the good old days, I had
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  90cm FortecStar dish
                  Maxx 110cm Dish
                  Technomate 2300 Motors
                  • alunfennell
                    • Oct 2008
                    • 1525
                    Creating a 100% legit rapid fire with NO soldering
                    Pics will be added later
                    Ok guys. Here's the thing. This isnt a true rapid fire MOD per say but it does help quite alot. What it does is that instead of pulling the trigger all the way, it makes it only go halfway. Now you may think how is this useful my controller wont even work. WRONG. The command that you pulled the trigger is sent only when the trigger is pulled halfway so doing this will make you shoot much faster, much easier, and much morelegit. Another plus side is that it works for all games and you dont need to take the mod out. So let us start.
                    Things you will need...
                    A wooden kebab (trust me guys)
                    A knife (make sure it can cut wood)
                    A T-8 screwdriver to take your controller apart
                    Not required but some tape would be recommended
                    Now that you have that done take your kebab and chop off the end of it (refer to the pic). Your gonna want to use the size of the piece on the right
                    Next- Locate the right trigger apparatus. Yours should look like mine except the colors of it. Note the circled section
                    Now what your gonna do is take your chopstick piece and slide it into that circled hole. It should fit perfectly. If not trim it down so it does or cut another piece.Mine broke as it was cutting but yours should be one piece and the trigger pull should be about 60% down when pulled.
                    Now when your done put your controller back together and test it. If it works congrats! If not go back and trim it a little bit so it lets the trigger go down more. Also you can use tape if it is loose to hold it in place but if you used my type of kebab then you wont .
                    All thanks to Rich123321 for this tut...
                    Regards:
                    Alun
                    **The Worlds Best Interactive F1 Strategy Game**
