Just bought X-Box 360 and can't connect!
  • dms05
    • Feb 2010
    I'm trying to set up my Grandson's X-Box 360 on X-Box LIve. The X-Box reports the Network and Internet connections are connecting and passing the tests but the final stage of connecting to X-Box Live fails.
    The failure usually shows up as 'Can't Connect' but has also shown up as MTU problem (untrue as it's set to 1500) or error on ICMP. When attempting to connect I'm offered an Upgrade but that fails, sometimes immediately and sometimes after the download bar has completed.
    I've been into the Sky Netgear (v1) router and set the X-box to IP 192.168.0.101 (which shows up correctly on the X-Box Settings Menu) for the correct X-Box MAC. I've set Ports UDP 88, UDP 3074 and TCP 3074 in Custom Services and set these in the Firewall (XBL1/2/3) .
    However I still can't manage a connection to X-Box Live.
    The X-Box is on a HomePlug network.
    Is this a problem with the Sky Router or something else? Any help would be appreciated!
  • djjwdubz
    • 1011
    here mate try update it yourself with a usb card.
    please dont thanks me if it works thank the guy whos link it is.
    download it an use a usb to update your xbox then try connect to xbox live
    • tonybod
      • 12
      This probably does not help much, but my Xbox here connects via homeplugs. And I did not have to open/forward any ports.
      It looks like it gets its IP address via DHCP, that's the only thing I would check.
      Tony.
