open tray error
  • antnik
    • 31
    open tray error
    Hi all, on my xbox 360, when i open the drive , it says open, then after i have inserted a game and close it ,its says closing, it then says reading for about 2 seconds then it says tray open . When i eject the tray the disc has not even moved. It worked fine 3 days ago, thanks in advance for your contributions
    antnik
  • samlen27
    • 168
    mine did exact same thing and it ended up i had to buy a new drive and put my key onto the new 1 and works perfect now
    • alunfennell
      • Oct 2008
      • 1525
      Yeah there is a small Running elastic band inside the drive that has sliped if the cog, sometimes by opening the drive Tray you can hook it back on with a bit of wire.
      Its nothing that can not be fixed, out of 10 this is a 3.
      **The Worlds Best Interactive F1 Strategy Game**
      • Leemond
        I have the same problem - I've discovered that by repeatedly hitting the top of the xbox the game will eventually load. I'm probably doing untold damage but I can't afford to get it repaired properly.
        • ezzda1
          • 172
          its not the elastic band, the laser will either be going bad or need cleaning or pushing back to the microswitch near the spindle, [ame=http://www.youtube.com/watch?v=ycuvX7x1HJk]YouTube - !!EASY FIX!! Xbox 360 Open Tray Problem[/ame]
          • djjwdubz
            • 1011
            if i was you don't do that cuz you will mess it up big time.
            • .: JaCkPoT :.
              Retired Sat TV Addict
              • 5607
              You need a new laser. Only a tenner.
              ___________________
              In the good old days, I had
              DM800s HD
              Openbox S10
              TM500
              DM500s
              90cm FortecStar dish
              Maxx 110cm Dish
              Technomate 2300 Motors
